Old 03-24-2001, 11:24 PM
Inherit67 Inherit67 is offline
Help Guys I'm at a standstill! How do you remove the black shifter knob so you can get console out of car. I have tried unscrewing the knob but this still will not remove it. I can get the indicator plate (cover) to slide toward the back a bit, does that mean anything? I need to wrap this up this weekend so any help is much needed. Thanks, JR
Old 03-25-2001, 10:43 PM
Kurt Zimmerman's Avatar
Kurt Zimmerman Kurt Zimmerman is offline
JR,
I'm pretty sure that bad boy unscrews counter-clockwise. Every shifter knob I've run into does.
Kurt
"folks nowdays just don't do nothin', simply for the love of it..."
Don Henley
Old 03-26-2001, 12:02 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
On Pontiacs with the button in the middle, it may require the removal of a little c clip.
Old 03-26-2001, 05:57 PM
jyeager jyeager is offline
I'm not sure about the '67 model, but like ccass said, you should pop out the button in the top of the knob using a flat-bladed screwdriver. After it's popped out, you will be able to remove the snap-ring that retains the shifter knob.
Old 03-27-2001, 12:55 AM
Thanks Guys. Its always the little things that trip me up. The little chrome button on top unscrews also. ( hard to believe that I am a 9-level aircraft mechanic in our USAF) After that delay things have gone smooth, some rust in floorpans but it was an easy fix. Thanks for the help, I'll be back!
