Old 04-12-2005, 02:49 PM
pontiacjim pontiacjim is offline
I've just traded for a 80 TA and the shaker keeps the hood pushed up about a half an inch. Some one put a 1976 pontiac 400 in the car and it just does not seem to fit. What's your thoughts, change intakes ?
Jim
Jim
Old 04-12-2005, 03:36 PM
bs78ta's Avatar
bs78ta bs78ta is offline
Did the shaker come off of the 80 TA?
Butch
Old 04-12-2005, 05:11 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
what intake is on the car? also if the 80 shaker is used it was made for a 301,403 or 305/350 chevy so that scoop will not fit a pontiac motor other than the 301 if that is what it came off of, I do have an air cleaner assembly that will work for you if you need it.
www.pro-touringf-body.com
Old 04-12-2005, 06:56 PM
Brian Baker's Avatar
403 shaker wouldn't fit, period, when used with a Pontiac engine. It is likely a 301 shaker, which would have been a little taller than a 400 shaker, since the 301 deckheight is 1" shorter. Look for a 400/455 shaker assembly.
Old 04-12-2005, 08:08 PM
pro-tour79's Avatar
Brian, thanks for the re-word it makes more sense than my post
Old 04-13-2005, 05:25 AM
doc9339 doc9339 is offline
There is an easy way to get your cuurent shaker to fit, but you will have to ditch the current aircleaner base, and all the associated hosing, air inatkes (no prob if you dont use it to begin with)
A drop base q jet air cleaner base will drop your whole air cleaner assembly about 1.5 to 2 inches
Old 04-13-2005, 05:30 AM
pro-tour79's Avatar
like this one!
Old 05-03-2005, 10:41 PM
troy_barker's Avatar
troy_barker troy_barker is offline
The question was asked eariler , what intake is on the car? Factory or after market?
I had an after market RPM and it set as you described. If I replace it with a pontiac it lowers the carb.
Bring back my 67 GTO: Shes ALIVE as of 2-19-13
previously owned
78 Firebird
67 Nova
64 Nova
Old 05-04-2005, 02:31 AM
LeighP's Avatar
LeighP LeighP is offline
A 403 top will fit on a Pontiac base....I know, I'm using one on my car. The scoop top has to be repositioned on the 403 adapter ring, but it'll clear under the skin of the stock hood (just)...I tried it. I'm currently using a Formula hood with the shaker hole cut into it...works perfectly for that application too.
You need to use the 403 clamp (the Pontiac clamps a bit small). The actual difference in diameter between the adapter and the base is only slight and doesn't seem to make any difference to the clamping force when the ring is tightened up.
Regards,
Leigh
Pontiacs I’ve owned….
1960 Laurentian 283
1963 Laurentian 283
1976 Trans Am 400
1977 Trans Am 400
1951 Chieftain Flat head 6
1967 Firebird 400 convertible
1967 Firebird 400 coupe
1979 Trans Am 403
1971 Formula 455 (clone)
1969 Firebird 350
1968 Firebird 428 manual.
Sydney, Australia
Old 05-04-2005, 11:33 AM
Larry Navarro's Avatar
PONTIAC JIM...
I can offer some assitance on your problem.
An assembly that can be taylored to your specific application.
email: [email protected]
