Old 03-18-2005, 06:25 AM
TA doctor TA doctor is offline
Do the 71 thru 76 pontiac Honeycombs have a washer before the lug nut ? I purchesed a set of lugs but are still shallow on the wheel.
Thank you
Thank you
Old 03-18-2005, 10:27 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Nope - the honeycomb wheels use the same stainless capped tapered seat lug nuts that the Rally II wheels use.
Regards,
"455HO" Lloyd
Old 03-18-2005, 12:18 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The lug nut hole on the rim may be reamed out by excessive use of an impact wrench. It happens a lot on Rally II rims. I've seen them so bad that the lug nut is pulling through.
My solution was to get some McGard bulge lug nuts that appear close to the factory stainless capped acorn lug nuts.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 03-21-2005, 10:34 PM
Jim Rotella Jim Rotella is offline
I'm running into the same problem with my KR Rally II's.The standard stainless capped acorn style lug nuts keep ridding deeper into the wheels and this forces the cap to slip upwards off of the lug nut.I've been going through lug nuts like crazy. Where's the best place to find the McGard lug nuts?
Old 03-22-2005, 07:38 PM
Sport71's Avatar
Sport71 Sport71 is offline
Don't know where to find the McGards, but just wanted to say "Welcome Aboard" Jim! If I go way out on a limb, I'd venture a guess that you're of the same "clan" as Rocky? The more Pontiac expertise available to the rest of us the better!!
Vince
1971 GTO 455 H.O. Ram Air
Nordic Silver - Black
Old 03-22-2005, 08:56 PM
Thanks for the greetings Vince.
Jim
