Old 05-13-2005, 09:37 PM
mothermuxer's Avatar
mothermuxer mothermuxer is offline
Before I start this 12" rotor/B-body spindle conversion, can anyone tell me if the 15" Rally II rims fit within the 12" rotor & caliper? Just don't want to get the conversion done, and then find out I need new rims after the fact. Thanks.
THREADKILLER
1975 Trans Am
THREADKILLER
1975 Trans Am
Old 05-13-2005, 09:44 PM
The 15X7 Rally IIs came on the B-body cars, so yes they will fit.
I put the 15X7s on my own car with B-body spindles/12" disc conversion, so I know they work.
Old 05-14-2005, 01:00 AM
Sweeeeeeet. How do you like the 12" fronts? I just finished the rear disc, and it made quite an improvement. Hoping for a bit more stopping power. You know... LA traffic and all that shiz.
THREADKILLER
1975 Trans Am
Old 05-14-2005, 09:24 AM
The car ('64 Tempest) stops like crazy, mine are manual (no power booster).
Of couse before the conversion it had drum brakes up front. But I can compare it to my '64 GTO which has 11" front discs from a '69 GP and big 11" Ford drums out back (has a Ford 9" rear end), also manual brakes.
The Tempest definitely stops better, even with the 9-1/2" stock rear drums.
Old 05-14-2005, 11:56 AM
Cool beans.
When is the next time you're running 1/4 miles up in Lancaster/Palmdale? I've been meaning to get up there for the Pontiac drags, but househunting & work keeps piling up.
THREADKILLER
1975 Trans Am
Old 05-14-2005, 01:10 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
PDD is racing at LACR Palmdale today.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 05-14-2005, 02:23 PM
DOH!!!!!!!!!!!!!!!!!!!!
THREADKILLER
1975 Trans Am
