Old 02-18-2000, 02:55 PM
LT's Avatar
LT LT is offline
What is the best front disc brake upgrade for the second generation Trans Am? I plan to retain the 15x7 Honeycombs on my '71 but would like to use 2 piston calipers. All responses are apreciated.
LT's Avatar
LT LT is offline
Old 02-18-2000, 08:50 PM
Tom McQueen Tom McQueen is offline
Since you want to retain the 15" wheels, you are limited to the disc size. I would check out Global West. They offer a 4 piston caliper and various disc sizes to fit whatever wheel (even 14's) and they will bolt up to your stock spindle.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 02-18-2000, 09:27 PM
Scott Misus Scott Misus is offline
LT:
What problems/shortcomings are you encountering currently that gives you cause to want to "upgrade?"
Old 02-19-2000, 09:56 PM
Chambers Chambers is offline
Wilwood has a trick bolt on kit with 4piston calipers, aluminum hubs, and vented rotors, and can use 15" wheel. Check out their site wilwood.com
Old 02-21-2000, 09:17 PM
Steve C. Steve C. is offline
You might also check out Baer Racing at 602-233-1411. They have a SS/Drag version with 12-in. front rotors for 15-in. wheels feature PBR calipers. With the bolt-in kit you will also get about a 20 lb.weight savings.
Old information here:
