Old 08-05-2002, 01:27 PM
jducharme1 jducharme1 is offline
I've got a 66 lemans that I'm trying to remove the wiper arms on and I'm not having much luck. I'm trying to work the tab on the underside with a small scewdriver but they won't let go. Would anybody let me in on the trick? Thanks
If it breaks it needed replacing anyway!
Old 08-05-2002, 05:10 PM
jim darlington jim darlington is offline
Once you released the small tab under the wiper arm , lay a rag folded over a couple of times on the cowl grille . Then using a small screwdriver , pry up on the arm , it will pop off . Try to do this without scratching or denting the cowl grille panel . Sometimes you can grab the wiper arm and wiggle it off by hand , it all depends on how long the wiper arms have been on .
Man is not complete until he's married , then he is finished !
Old 08-05-2002, 06:05 PM
Do I push the tab away from the post?
Old 08-05-2002, 11:28 PM
McLeod McLeod is offline
There is a wiper removal tool available.
I think I saw it in Year One or Ames.
65 Pontiac
67 EB
93 F150 4x4
95 Bronco
Old 08-06-2002, 05:51 AM
Yes , you push the tab away from the post .
