Old 06-19-2002, 05:20 PM
LAW003 LAW003 is offline
Any suggestions on a heat shield for a stock starter on a 1970 GTO running Hooker headers? My starter is getting cooked!
Thanks for any advice.
Old 06-19-2002, 05:34 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
I know most of the big parts suppliers have a heat shield. I's just a piece of sheet metal though. I'm not sure if it does much good.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 06-20-2002, 04:48 PM
thepontiacman's Avatar
Some late 70's Pontiacs came with starter heat shields. Most performance shops have or can order shields for your starter. Also available is a material that wraps around the starter to shield it. They also make wrapping for the headers. i also recommend a shield for the solenoid and a heat soak spring to put in the solenoid. Other alternative would be to go to a mini-starter, available through most racing suppliers. [email protected]
Old 06-21-2002, 08:35 AM
HANDSEL HANDSEL is offline
I have one that I will sell you for $5 I am not using it since mine starts fine without it. Email me if you are interested [email protected]
Oh it's an aluminum shield that goes over the solenoid between the header and starter.
[ June 21, 2002, 08:37 AM: Message edited by: HANDSEL ]
