Old 03-18-2003, 10:34 PM
acowboy acowboy is offline
need some help from you guys that have been there....am finishing a 70 goat, and bought a MH engine wiring harness...the car had been altered, and has no TCS sensor in the intake, or any temp sender at all...car has idiot lights....the wiring harness has the three prong female connector, and no other wires for the temp sender..am not concerned about the TCS being operational, but am concerned with origional look...any suggestions,how did you do it??
Old 03-19-2003, 11:52 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
I have been thinging about this and the only thing I can think of is to carfully remove the wires from the connector and then put some shrink wrap over them and try to hide them in the harness. Or, cut the wires off close to the harness and twist them under so you can't see them. Other than that, try calling the people you got the harness from and see if they would give you a trade in value for the right one, or just get the right one and sell that one on eBay.
Good luck.
Jack
TigerEFI.com (Classic Pontiac Fuel Injection) [email protected]
Motto: Build it for NASA and drive it like you stole it!
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
Old 03-20-2003, 03:28 PM
first, thanks for the reply jack.....i did call m&h yesterday, and their reply was to order an adapter for this purpose...goes from the 3 prong female to a single prong temp sender for gauges...wont be right, but, guess its the best solution
Old 03-20-2003, 03:44 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
I bought my temp sender for my 70 GTO(w/gauges) at napa and it came with the connector to slide a wire into it. I removed the green wire from the 3 prong plug and snapped it into this plug and that was it. I just left the plug with the 2 remaining unused wires aside and will probably end up removing the plug and taping the ends into the harness. Hope this helps some..
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 03-20-2003, 08:26 PM
Forrest's Avatar
Forrest Forrest is offline
if you want it to look original why not get the 3 prong tcs sensor( one that doe`nt work is o/k) plug the 3 prong connector to the adapter and the other end of the plug to the sensor then hook up the other wire for your temp sending unit (if your using a stock intake there is two holes on the intake one for the tcs and one for the temp sending unit) and it will look abslutly original!
Old 03-20-2003, 08:44 PM
that is exactly what i wanted to do forrest...but, have no idea where to get the TCS 3 prong sender...everyone ive talked to said long discontinued....any suggestions appreciated
