Old 05-10-2005, 05:15 PM
Derding's Avatar
Derding Derding is offline
Take a look at this picture(I finally learned how to resize it so it'll work on this site)
Does this look right? I'm concerned because the inlet for the vacuum hookup isn't positioned correctly. Should I flip it over and run the hose behind the MC?
Derding's Avatar
Old 05-10-2005, 08:41 PM
what are you talking about?
the fitting's in the correct position and it should swivel in the booster housing.
mike
former." --Albert Einstein
- Winston Churchill
Old 05-11-2005, 05:17 AM
Derding's Avatar
The problem I'm having is it doesn't swivel. I'm afraid I'll brake it if I try forcing it.
Old 05-11-2005, 11:47 AM
winbub's Avatar
winbub winbub is offline
Derding-
Mike is correct...the vacuum hookup rotates 360*. I just installed a new booster in my car and it easily rotates.
Is this a new or reconditioned booster? Who did you buy it from? Sounds crazy but I saw one guy put gasket sealer on the vacuum hookup gasket "for a better seal". Couldn't turn that sucker for anything.
JB
1966 GTO Coupe(#1845), AT, PS, PB, Nightwatch Blue
389 built by Gaydosh Performance - .040 over, 670 heads, 4bbl 750 Holley Double Pumper, Edelbrock Performer intake, Howards CAM and lifters, Scorpion roller rockers, TRW rods and pistons, Doug's headers, new TH350 with shift kit & 2000 stall, 8.2" rear with Auburn carrier & 3.55 posi Richmond gears
http://www.cardomain.com/ride/2240898/1966-pontiac-gto/
Old 05-11-2005, 04:40 PM
Derding's Avatar
After putting a pliers onto it I was able to get it to rotate. I was afraid of snapping it off, but luckily I didn't. Not sure what was holding it. Thanks for the info everyone!
