Old 04-29-2003, 08:05 PM
goatless's Avatar
goatless goatless is offline
I'm switching intake and carb on my '69 Lemans. Going from the original 2bbl to Qjet. Will the throttle cable work on the 4bbl?
Thanks, Jeremy
1966 GTO
goatless's Avatar
Thanks, Jeremy
1966 GTO
Old 04-29-2003, 08:55 PM
cuz68's Avatar
cuz68 cuz68 is offline
yes
Cuz68
Old 04-30-2003, 06:43 PM
Linden Green 67 Linden Green 67 is offline
NO! You will have to find the correct throttle cable for your Q-jet. I found this out the hardway, GTO's had different throttle cables for each carboration, no two were alike. Good luck in your search, you need to be VERY careful you end up with full throttle when youre done!!!!
Old 04-30-2003, 07:06 PM
goatless's Avatar
Hmmmmmmm....
1966 GTO
Old 04-30-2003, 08:50 PM
cuz68's Avatar
Tell me why not, Linden thay are some ajustments on the bracket?
Cuz68
Old 04-30-2003, 09:01 PM
PY sells the correct 1968-1971 4-barrel throttle cable for about $32, part# GME127.
Let's go racing!
www.outlawpontiacs.com/members/B-Man2.php
www.outlawpontiacs.com/members/B-Man.php
Old 05-01-2003, 04:21 AM
goatless's Avatar
Thanks for the input guys. I've actually got a 4bbl cable available on my parts car. At quick glance they appear the same. However I did notice that Ames and PY sell cables that are listed for the 4bbl only. So I'm trying to find out if they are the same or not. I just don't want to spend time tearing out a part and replacing it with the identical part. Looks like I'll take 'em both out and lay them side by side.
1966 GTO
Old 05-01-2003, 01:32 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
I am pretty sure its just a slight difference in length.
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
