Old 03-07-2005, 11:20 AM
runningman runningman is offline
I replaced the front coil springs on my 67 GTO a couple years ago, when both the motor and front clip was removed. Now that the car is almost finished, I've developed a sag in one of the springs. I've heard where a "preloading" condition could exist, whereby the sagging spring is actually correct and the opposite side is too high (preloaded). Both springs are seated correctly. Moog is the manufacturer of the springs. Anyone have any experience with this preloading condition? How do you correct it? Re-installation?
thanks...
thanks...
Old 03-07-2005, 03:52 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Loosen the upper control arm shaft bolts and lower control arm mounting bolts to free everything up , the bushings have little jagged teeth that bite into the metal and need to be released-and than jounce the front suspension , push up and down on it a few good times.that should settle everything to its proper position.
Measure ride height first , than check after to see if it's moved.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 03-08-2005, 05:53 AM
cujo cujo is offline
Remember that all bushed suspension nuts and bolts should be torqued to spec with car at curb ride height (all weight of car and engine on the suspension).
Old 03-08-2005, 10:47 AM
Thanks for the suggestions guys. Given what I DIDN'T do during the installation process, these seem to make a whole lot of sense. I'll give them a try this weekend.
Old 03-14-2005, 09:49 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
I replaced fronts with moog also, remember there being a left & right side spring as well as top & bottom. they were marked I believe with a dab of white paint. could be, if your car has a/c it will settle to proper ride height with install of motor.
70 GTO 400/[email protected]
