Old 07-02-2005, 04:32 PM
silky58 silky58 is offline
i was running at 210f with one 1650 cfm 14" fan and a milodon water pump on my 455, well i grabbed a 2950cfm hp prema cool fan also 14" to go next to it, and wow!!!! i dropped from 200-215 to 160-170, just like that
funny thing is both fans are 14" perma-cool but the 1650 stanard cost 103 in jegs and the high performance model only cost 94 for a 2950, why oh why didn't i buy the hp to start with.
now running 4600 cfm amd she likes it
silky58
Old 07-02-2005, 07:53 PM
quick67bird's Avatar
quick67bird quick67bird is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by silky58:
silky58 </div></BLOCKQUOTE>
Do have part numbers I am in the market for fans too. Thanks
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 07-03-2005, 07:57 PM
here is the hp fan 14" that worked out for me.
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1114&prmenbr=361
and here is the standard one that didn't lol
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1132&prmenbr=361
silky58
hope this helps
Old 07-03-2005, 08:12 PM
Geeto 67 Geeto 67 is offline
how do you have them wired to go on? Via switch or thermostatically. I had an aux electric fan in my GTO and a thermostatic switch that sat on top of the battery, it shorted out in a week.
Old 07-04-2005, 08:54 AM
Thanks Silky58. That helps a lot.
Robert
Old 07-04-2005, 09:39 PM
ER's Avatar
ER ER is offline
Any pics ? Curious how you set this up.
ER
Old 07-05-2005, 07:31 AM
I wana know how many amps it pulls.
Mike
Old 07-05-2005, 10:40 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
I'm getting ready to use a dual fan setup from an 97 LT1. Does anyone know what the CFM rating for these fans are??
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 07-06-2005, 09:50 AM
ok here is some info
1. i have two seprate fans one 14 standard fan i bought a few months back which alone had me running at 210 i then added a hp fan right next to it, this dropped me to 165-175.
2. both are o the same rely activated by a swith under the dash.
3. the stand perma cool 14" draws 8 amps, the newly added hihh performance perma cool 14" fan draws 9.5 amps.
4. the fans are side by side i have a 28" rad and two 14" fans that cover the whole rad.
5. i will have pics soon.
silky58
Old 07-24-2005, 08:43 AM
GOAT72's Avatar
GOAT72 GOAT72 is offline
Send a message via ICQ to GOAT72
</div></BLOCKQUOTE>
Silk,
Do you think it was just the fact that you added more volume with a 2nd fan?
Or do you think the higher volume fan, mounted centrally, would do the job?
I'm going with a 4-core, but want the added insurance of a fan when i hit traffic. My highway temps are OK now, and hopefully will improve slightly with a 4-core, but those thraffic stops are killers and with a fan I would have another option besides pulling over and popping the hood in 90+ Virginia heat.
SO, the question was: will one higher-volume fan work or do you need both?
Thanks!
Subscribe to PY's PONTIAC JOURNAL!
This month: Interview with Sean Mattingly/ The Stay Goats of America Club/PY's "MOM AWARD" Member of the Month: who will it be?
Old 07-24-2005, 06:13 PM
70GS455 70GS455 is online now
I was thinking about running 2 Mark VIII fans. 9000 cfm is good, but the 200+ amps at startup and almost 70 amps continuous kinda killed the idea.
Old 07-25-2005, 11:44 AM
Formulafr's Avatar
Formulafr Formulafr is offline
Send a message via ICQ to Formulafr Send a message via AIM to Formulafr Send a message via Yahoo to Formulafr Send a message via Skype™ to Formulafr
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by KMac:
</div></BLOCKQUOTE>
i'd like to answer you, but my single 18" (9-10amps) perma cool fan is not installed yet. waiting for some parts to complete install.
Old 07-25-2005, 06:31 PM
GTOJOE228's Avatar
GTOJOE228 GTOJOE228 is offline
Three questions: 1)Are these in place of the stock fan? 2)Can you mount this fan in front of the radiator? 3)What would you call this fan a pusher or a puller? Joe
1966 GTO Conv't, 4-speed, Tri-Power(sold)
1967 GTO Ram Air, PHS Doc. 4sp, #'s match, 15+ options 1 of 751
(Featured on Cover plus 6 page spread in May 2006 HPP)
1970 GTO Judge, PHS Doc. 4sp, #'s match, Ram Air III
2006 GTO Spice Red. M6,18" wheels, 400 HP LS2
richmondcountypontiac.com
Need High Quality Printing fast and reasonable?
www.farbetterprinting.com
Since 1974
Quotes at: [email protected]
Old 07-26-2005, 12:39 PM
Formulafr's Avatar
for my install, the fan replace the mecanic one and mounted as a puller, 'cause it move more air than the pusher.
yes you can mount it in front.
puller fan is behind the radiator (between rad and motor).
pusher is in front of radiator.
Old 07-26-2005, 01:55 PM
GTOJOE228's Avatar
Would a simple wiring hook up do? Say a switch and a tap off the existing fuse box. I'm not sure how much draw the 14" fan uses?????
Since 1974
Old 08-02-2005, 10:31 AM
GTOJOE228's Avatar
Thumbs up How big of a fan is too big?
I plan on putting this Jegs fan in front of my radiator. Is there room for say the 16' version of this fan? It will sit dead center and push the air through the radiator into the stock fan. Anyone have some info? Thanks, Joe
Since 1974
