Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 08-05-2002, 11:49 AM
m trower m trower is offline
does anyone know where i can find shifter bushings for my 64 gto with the original shifter.i was told by the folks at year one that theirs would only work on the hurst shifter.
Old 08-05-2002, 04:05 PM
Ed Neasham Ed Neasham is offline
Mr. Gasket makes a "Pit Pac" that has the bushings in it for GTO shifters. I believe they cover the '64 too. I'll check my catalog when I get home tonight. I also believe they come in nylon (original style) which are quieter or metal (which makes for crisper shifts).
Old 08-05-2002, 04:29 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Use the metal. Do it right the first time. Ask me how I know this. ;)
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 08-05-2002, 06:16 PM
73ta's Avatar
73ta 73ta is offline
Ok, I'll bite. How?
Old 08-05-2002, 07:55 PM
Jack Peters's Avatar
I don't understand Year1's problem. Your car came with a HURST SHIFTER. Just it is oem style not aftermarket. Which do you have. Still go metal.
I would guess the reason would he couldn't get in or out of gear WITHOUT CRAWLING UNDER IT. :D
JLP
Old 08-05-2002, 09:37 PM
Bud Lyons's Avatar
All I've used were plastic bushings. I've locked the shifter between gears too many times. The last time was at Maple Grove. :mad: I talked to Pontiac Dude and he says "get rid of the plastic and use metal".
Old 08-05-2002, 11:24 PM
Bud, Puts a new meaning to "I've got a hangup" don't it. :D OEM shifters all had them. Metal is always better as there is not as much give to them.
I still don't understand Y1's problem in telling him that they only had them for "HURST" shifters. Y1, this isn't a C, with the MUNCIE "really hung up" SHIFTER. Does PY have them? I have not checked. CCass, are you there????? Sorry for the tirade. [img]redface.gif[/img]
[ August 06, 2002, 12:07 AM: Message edited by: Jack Peters ]
JLP
Old 08-06-2002, 10:56 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Hurst Pit Pak PY #M33170 $11.00 7 CLIPS & 7 metal BUSHINGS. Now if we are talking about components to rebuild the shifter itself, that's a different story.
Old 08-06-2002, 12:33 PM
Old Man Taylor's Avatar
Isn't the bushing different between the factory shifter and the "over the counter" Hurst Competition Plus? On the factory shifter the rod itself goes into the shifter. On the aftermarket Hurst it is cylindrical portion of the screw on piece that goes into the shifter. I am not saying the aftermarket bushing won't work, just check it closely because the configurations are different.
Old 08-06-2002, 05:32 PM
OMT, I think you are right. Don't remember which is which, but one is threaded on the shifter linkage end and the other is threaded on the transmission lever end.
JLP
Old 08-06-2002, 08:53 PM
Scott Misus Scott Misus is offline
Moving to "64-72 GTO tech........."
Smilies are Off
