Old 03-08-2003, 04:53 PM
UnchainedGTO's Avatar
UnchainedGTO UnchainedGTO is offline
I need to remove the kick panels from my 69 Lemans non AC car. There are no screws to be seen. What is the proper way to remove these. The car has the dual vent levers.
Thanks,
Unchained
Thank you,
Don
1963 Lemans
1965 Catalina 2+2
1968 GTO
1969 Lemans OHC6
1972 Formula
1974 GTO
1986 Grand Prix 2+2
1986 Fiero SE
2005 Bonneville GXP
Thanks,
Unchained
Thank you,
Don
1963 Lemans
1965 Catalina 2+2
1968 GTO
1969 Lemans OHC6
1972 Formula
1974 GTO
1986 Grand Prix 2+2
1986 Fiero SE
2005 Bonneville GXP
Old 03-08-2003, 08:21 PM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
You'll have to remove the emergency brake assembly on the drivers side. Remove the vent grates from the panal and you'll fine the screw that hold the panal in place.
Good Luck,
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
Larry Metzger
Columbus, NJ
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
Old 03-08-2003, 10:00 PM
Larry,
Is there any secret to removing the vent grates? Should I assume they will pull out with a snug pull or are they held in by screws? I did not see anything attaching them either.
Thanks,
Unchained
Thank you,
Don
1963 Lemans
1965 Catalina 2+2
1968 GTO
1969 Lemans OHC6
1972 Formula
1974 GTO
1986 Grand Prix 2+2
1986 Fiero SE
2005 Bonneville GXP
Old 03-08-2003, 10:08 PM
No secret, just pop them out with a screwdriver. I just went out to the garage and looked at one. They are held into place by 4 plastic tabs around each corner.
Larry Metzger
Columbus, NJ
Larry Metzger
Columbus, NJ
