Old 04-23-2005, 02:16 PM
78firebird 78firebird is offline
I have a 78 firebird with a 400cu engine. I am installing guages and don't know where the oil pressure sending unit is so I can hook up a mechanical one... Not the most mechanically minded individual...LOL
Thanks for your help!!
Old 04-23-2005, 02:25 PM
The factory oil pressure sender is screwed into the back of the oil filter adapter, just above the oil filter itself. Right where it's conveniently hard to reach.......
Old 04-23-2005, 02:26 PM
Thanks, thats where I thought it was but it did not look like it unscrewed so I can put the autometer threaded adapter in.
Old 04-23-2005, 02:34 PM
WDCreech's Avatar
WDCreech WDCreech is offline
The best place to get the oil pressure is on the distributer pad. There is a plug that takes a 5/16 square drive to get out. I chased a Snap On truck down the road, to get a socket for taking one out.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 04-23-2005, 02:35 PM
You can also remove the filter adapter from the block to make it easier to attach your fittings, it comes off by removing 3 bolts. All you'll need is a $2 gasket to put it back on.
