Old 02-09-2003, 06:16 AM
Pontimaniac's Avatar
Pontimaniac Pontimaniac is offline
Anyone know of a product that works well to replace the factory mastic used between the hood inr and otr panels?
Old 02-09-2003, 06:44 AM
61man 61man is offline
All I know is that you want something that stays soft and plyable, If it sets up hard it will wrap the crap out of the sheetmetal when it expands and contracts.
http://kurtspontiac.homestead.com/Pre1964Pontiacs.html
Old 02-12-2003, 08:44 AM
Half-Inch Stud's Avatar
Liquid Nails
practice
practice
practice
then try it
"tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs
11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs
12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
Old 02-12-2003, 08:47 AM
Liquid Nails appears dry, but it will bubble-up most paints.
FWIW 3M black weatherstrip adhesive also bubbles-up car paint.
The alternate idea: I tried Dum dum..does not hold under tension if the plys are gapped away.
Old 02-13-2003, 04:43 PM
Thanks 1/2". Seems like an open market. Gotta be lots of hoods that could use the same help.
Old 02-14-2003, 03:24 PM
73redTA 73redTA is offline
I haven't tried this stuff but it is from Fusor so it must be OK. The description sounds like what is needed for a hood or trunk panel.
anti-flutter foam from Fusor
Keith
Old 02-15-2003, 05:11 PM
Thanks Keith, this stuff looks promising!
