Does anyone know of a web site or book that has the flow numbers for various stock Pontiac heads. In particular I am looking for the numbers for 1968 #16 heads on my 400.
Thanks, Unchained
Thank you, Don 1963 Lemans 1965 Catalina 2+2 1968 GTO 1969 Lemans OHC6 1972 Formula 1974 GTO 1986 Grand Prix 2+2 1986 Fiero SE 2005 Bonneville GXP |
Thanks, Unchained
Almost all the D-ports flow within a couple CFM of each other. I would say around 185+- CFM on the intakes.
Try the April 1991 issue of HPP.
------------------ Bill
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. [email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
heres the site you need....... http://www.pontiacwarriors.com/
Home of WFO Hyperformance Shaker induction. |
Try this link. I think it's the article that WDCreech is talking about:
http://clickit.go2net.com/adclick?ci...eddedexitpopup |
Sorry, wrong link......don't know where that came from? Try this one:
http://www.pontiacpower.org/ultimateflow.htm |
Keep in mind that these numbers are flowed at 12 in. hg. Is there a reliable conversion factor to 28 in. hg ?
The above flowbench tests should be interpretted as a comparison of the heads that were analysed at the time. They were originally tested at 12". Conversion of these figures to 28", & subsequent comparison will have some scratching their heads, wondering "what if" all of the heads tested had been tested in #1 shape.
If your heads are ones that were shown as #2 condition or #3 condition (the '71 HO's) in the above tests... might do as I did, & pay to have several sets of near identical #1 condition heads flowed on a Superflow 600 at 28", you will get a far more accurate result.
76 T/A,
The conversion factor that was used in the "for beginner's" simulated dyno test was 1.2333
Unchained, I flowed a few pair of stock D-ports at 28" on a Superflow 600. The intakes flowed 210 cfm, the exhausts flowed 160 cfm.
Thank all of you for the information. I have been able to find the information needed from your responses.
Unchained
As they said above that article in HPP is good for comparisons of those heads tested. ven converting their 12" numbers come no where close to any numbers I have even gotten.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Conversions from 12" HG are inaccurate. If you want useable flow figures, it should be done at 28" HG. That's where a V-8 engine spends most of it's time while actually running- and that's the figure most shops insist on using for the past 20 years.
