Old 12-29-1999, 12:21 AM
Bobtempest Bobtempest is offline
What are the BEST headers if my friend puts a 455 with Edelbrock heads into a 66 Lemans? This is a 600 plus HP engine looking for 10 sec pass in a 3700 lb car. Brand and size??
I just want to confirm my ideas.
Bobtempest
Going fast with class!
'67 Tempest @ 11.26 at 3850lbs with air & Q-Jet
March 98 Car Craft
Bob
Bobtempest
March 98 Car Craft
Bob
Old 12-29-1999, 09:56 AM
Tom Hand's Avatar
Tom Hand Tom Hand is offline
Exhaust Guru
Bob, One of my sources said Hedmans fit that chassis well but the ones they checked were 1.75" diameter versions. I suspect that car will need at least 1.875". I do not have any other experience but will ask around. I know others on this site have done this before so I expect you will see many good suggestions. (Gach, what did you use on the GTO you helped with?)
(Bob, I reread my notes and the car they had put the Hedmans on was a 67. Not sure I can say that I know the 66 and 67 were identical; I seem to remember they are not. Sorry for the wrong information).
Tom Hand
[This message has been edited by Tom Hand (edited 12-29-1999).]
Tom Hand
Old 12-29-1999, 04:30 PM
boykoman boykoman is offline
Try Tom Dawson Racing He did my tri-steps for my high compression 455 ram IV heads were a work of art and reasonable. His # is 1-909-928-0969i.e. he has a lot of experience with pontiacs!
Old 12-29-1999, 11:19 PM
Brinson Pachar Brinson Pachar is offline
Bob, I just went through some of the same issues with my car. It is a 70 gto with 455 and E-heads. The only two headers I found available was Hooker round ports and Hedman Hustler round ports. The Hookers have 2" primaries (pt # 4201-1 for my car), I ordered and sent back due to poor quality for 450.00.
Hedman makes a 1 3/4" primary and the quality was much better. Other than those two you may have to go to a custom header. Seems like Edelbrock would come out with an application.
77 Formula
8.47@ 158
70 GTO-11.37 @ 117.7
Old 12-30-1999, 12:26 AM
Frank Frank is offline
Hooker does not make a round port header for the 64-67 chassis. 68-72 version will not fit! Hedman Husler makes a set in either 1.875" or 2" with a flat collector.
Old 12-30-1999, 01:22 AM
roger van doren roger van doren is offline
Any body have a set of factory ram air type headers they want to get rid of I heard these were the best for a street car.
Old 12-30-1999, 01:25 AM
these headers /\
for a 67 wit 400 thanks
roger
Old 12-30-1999, 02:25 PM
KO KO is offline
Hedman #35030 for 64-67 A body with round port heads 2" primary/ 3 1/2" collector.
1989 Automotive Hall of Fame Inductee
Old 01-03-2000, 12:52 PM
Paul Spotts's Avatar
Paul Spotts Paul Spotts is offline
KO has the answer. I run 2" hedman's with my d-ports (630 HP) If your running a victor intake and dominator - i would go 2" - seems to have a good balance.
www.spottsperformance.com
East Coast Pontiac engine builder - still going strong
4 month waiting list
email [email protected]
1981 Trans Am 455 w/6X heads 4 speed 4 wheel disc (for sale)
1969 Trans Am clone 9.79 at 139 so far
1964 Banshee clone project - Opel GT platform
Old 01-03-2000, 06:29 PM
KO KO is offline
There really is no choice (next to custom) for round port headers. 1 7/8"-2" is the norm. I have used big tube headers with no loss of low end. Actully seemed to be faster everywhere 60', 1/8th etc.
Old 01-04-2000, 01:16 AM
Old Man Taylor's Avatar
I have a set of round port "Headers by Ed" that are 1 7/8" on a '64 Tempest with E-heads. That is the largest he makes. They are outstanding headers, but very pricey. I believe they are now about $900, and they usually take a few months to get. If you are interested, I have a lot of pictures scanned to show how they fit.
Old 01-09-2000, 11:53 AM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
If you are looking for the best header you can buy and are made, just for your car, round port or d port. Headers by Ed are the best you can get No qustions asked. The are sometime in the HP pontiac mag.Not Cheap. They made me a set many years ago which I still have,Number 7&8 go outside the chassis,through the wheel wells. This header was on my 65 GTO with round port heads. Nuniz helped with this car and also used this headers on some of his cars.
