Old 02-03-2005, 10:28 PM
wyorm1mechenic wyorm1mechenic is offline
one question....will a 5.0 pontiac engine from a 88 firebird bolt up to a 88 chevy 4x4 pu???? what changes are nessecary???/thanks Terry
Old 02-04-2005, 01:32 AM
BVR421's Avatar
BVR421 BVR421 is offline
there was no Pontiac motors produced for Firebirds after 81, just Pontiacs with various GM motors, Firebird in 1988, it is a 305 chevy motor
Old 02-04-2005, 07:07 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Yes it will bolt up as they both are Chevy engines. You might have to use the intake and TBI injection from the pickup though.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 02-04-2005, 07:20 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Some of the 305's I've seen have a sizable weight on the flexplate and when its used on a 350 causes a nasty vibration. Im guessing 305's are externally balanced?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 02-04-2005, 07:43 AM
In 1988, I believe they changed the balancing on all SB chebbies. They did this a the same time they went to the one piece rear seal. If you stay within the same years the 305 and 350 flywheels interchange.
Old 02-04-2005, 08:16 AM
gotpontiac gotpontiac is offline
I put a 1989 305ci firebird engine in my 1983 truck.
Bolts right in, had to swap the flywheel for a new
flex plate, modify my `83 q-jet intake to fit the
heads, used my 83 distributor(w/MSD of course)truck runs great.
Greg
1969 Firebird/400/th400/3.42:1 rear
1/4=? MPH=? (WIP)
1983 1/2 ton Silverado/lwb/305 (89 FB)/
MSD ign/Mallery coil/83 intake/
700-r4(rebuilt w/shift kit and corvette servo)/
3.73 gears/31x10x15 all terrains.
10.9 1/8 mile. 17.xx 1/4 mile
1996 C2500/6.5L TD/4L80e(shift improved),4" exhaust
cold air intake, mechanical WG controller
3.73 gears/265-75-16 w/Eagle allows.
2002 1500 Suburban/stock
1986 Fiero GT,needs engine.
