Old 10-05-2005, 12:37 PM
Jim Heit Jim Heit is offline
Thumbs up Help on 64 GTO Code Numbers
Hello,
I'm looking at purchasing a 64 GTO Hardtop that has been sitting for about 3 years. It is in decent shape with no major body work required and only a small amount of rust on the right rear quarter panel. If purchased, I would consider doing a frame on or perhaps frame off restoration. I need a little help on some of the code on the firewall such as: Body PO16739, ACC 1E-5N-50 and TRIM 214. The car is a 3 carb car with a Hurst Shifter. The paint code is W which indicates that it should be Nocturne Blue but the car has been repainted a rust color or perhaps it was red when repainted. Also, any idea on what kind of price I should be paying considering that the mechanical components are all okay and no engine, transmission work would be required.
Thanks in advance for your help.
Jim in Simi Valley California
Old 10-05-2005, 02:03 PM
bdk1976 bdk1976 is offline
You might want to post this to the 64-65 GTO/Lemans section for more responses.
That being said, based on the condion stated, I would venture a guess that you are looking in the 10k range (+/- one or two thousand) as a fair price for something like that. Pictures (especially detailed ones) would help a lot.
Old 10-05-2005, 06:57 PM
Default 64 Pontiac GTO
Thanks for the guidance. I'll try and copy it over to that forum.
Jim
