Old 10-19-2005, 05:45 PM
pontorquer's Avatar
pontorquer pontorquer is offline
Smile Timing cover #'s
Hi Fellow Pontiackers ! Is there any site on the web about timing covers decoding for 64-65-66-67-68-69-70-71... Pontiacs V8 ? Thanks! Pontorquer
Old 10-20-2005, 12:07 AM
Gordy Doyle Gordy Doyle is offline
Default Use this sites search features
search this forum. there's lots of good info right here on timing cover numbers
Gordy
Old 10-20-2005, 01:26 AM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
#9773370 for 64-65 all, #9783129 for 66-67 all, #9790346 for 68 f,t, and large car, #482893 for 69-75 all, also # changed to #527291, #527291 for 76-79 all with cast timing mark, #526984 for 76-79 all without the cast timing mark.
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 10-20-2005, 04:35 PM
pontorquer's Avatar
Thanks guys ! Isn't there also another # for 1965-66 Tripower ? Pontorquer
Old 10-20-2005, 04:49 PM
Pontorquer,
Following are '69+ timing cover casting numbers followed by corresponding part number & actual useage. Majority of these part #'s have been discontinued for umpteen years, so if undergoing a high point restoration, the timing covers will have to be sourced in nice used shape.
Casting number
9790347, pn 9790346: 1968 Pontiac V8
9796346, pn 9796346: 1969 & 1970 Pontiac V8
482883, pn 482893: 1971 through at least 1975 Pontiac V8's (swear I've removed them from '76's as well). These will work on '69's & 70's, but are not numbers matching correct.
Research has shown that the positioning of the 482893 casting number is more to the lh of center (within 1/2" of the timing "stob") on '74 & '75 timing covers. The later 482893 timing covers also have a circular date imprint, with the year (usually '74 or '75) in the middle. There also was 482893 timing cover with the casting number cast haphazardly up & down a little. Lastly, the early 482893 timing covers I have sourced, the 482893 casting number is basically dead center, & below the number will be the diamond shaped DIECAST vendor mark.
'67 & earlier Pontiac timing covers:
9783130, pn 9783129 is the '66 timing cover. Have several of these.
Somewhere I have a copy of the Classic GTO Newsletter (circa '79-80?) & I believe it broke out the '66 as having a different part number than the '67. In this newsletter, Dr Phil Baughman had pics & breakdowns of many of the original waterpump castings, & he provided casting & the part numbers for the timing covers. Do not have its casting number handy, but the late '63, '64, & '65 have the smallest "stob" with timing marks, & that is how I've always sorted the late '63-65 timing cover from the '66's & '67's.
Hope this helps.
Old 10-20-2005, 04:55 PM
The '66 tripower engine used same timing coiver as std '66 engine. The main reason one usually has to worry about a timing cover when installing on a '66 tripower engine, is the timing covers up through at least early '74, had a recess cast into the top back to clear a tripower water neck. On several '66 -68 engines I've put together p/s set-ups & timing covers to utilize the '69+ style of timing cover & '68+ dampers. On two, these engines were equipped with '66 tripower & attention had to be paid that was not furnishing the non recess late model timing covers.
Old 07-15-2008, 09:40 AM
grivera's Avatar
grivera grivera is offline
"#526984 for 76-79 all without the cast timing mark."
Anyone know if this is confirmed to fit a 69 400?
Old 07-15-2008, 09:43 AM
grivera's Avatar
Also for the casting # 526985 ?
Old 05-15-2025, 06:28 PM
65madgoat's Avatar
Does anyone know what year timing cover this part # 482893 is -- does the "1" under the cast number signify 1971?
Cast number is 482883 --- with just a "1" underneath that.
Old 05-15-2025, 07:18 PM
grandam1979 grandam1979 is offline
1971 is what I found
The Following User Says Thank You to grandam1979 For This Useful Post:
Old 05-16-2025, 04:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My 78 looks about the same as all mine with cast timing marks.
Skip Fix
Old 05-16-2025, 05:25 PM
steve25 steve25 is online now
The 523 thru 527 prefix numbers are 57 only .
The 481 thru 484 prefix are 1971 only numbers.
