Old 11-04-2005, 02:26 AM
jamesgennock jamesgennock is offline
Question 1970 GTO Hood alignment
My 1970 GTO Hood lines up everywhere except it will be alittle high in the middle of the hood where it meets the middle of the endura nose. I have seen others with this problem. DId my nose shrink? I would say I need to adjust the hood but it fits perfect everywhere else and it is a real GTO hood. What do you guys think? Thanks James
JJG
Old 11-04-2005, 06:34 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
I know if I shut mine a little harder it will close further in this area. only other thing I can think to do would be to raise or cock bumper slightly. good luck.
70 GTO 400/[email protected]
Old 11-04-2005, 01:11 PM
DIYGuy DIYGuy is offline
Same here, mine wants to sit slightly high - If I close it harder, the latch has a 'ratchet' that will hold it down. Seems brutal, but that works for me.
On my '70 Le Mans, I can adjust the plastic nose piece that sits above the chrome bumper slightly by loosening bolts and moving the center of the nose up, then tightening the bolts, but there's not much adjustment available.
Bought: 1970 Le Mans Sport Convertible (second owner,) Palladium silver, 350/2bbl (sigh) with Comp Cams 268H grind (installed by previous owner), TH350 Trans. Mods: Front suspension: Global West negative roll tubular upper arms, Del-a-lum bushings, Koni shocks, 12" disc brake conversion, 1.1" front sway bar, Rear suspension: Global West tubular control arms, springs, sway bar. Exhaust: Flowmaster 2.5" American Thunder system. Mostly complete: Firewall-forward engine compartment restoration
Old 11-04-2005, 10:02 PM
Thanks guys!
JJG
Old 11-09-2005, 10:01 PM
GTOYANKEE1970's Avatar
GTOYANKEE1970 GTOYANKEE1970 is offline
Send a message via AIM to GTOYANKEE1970
Another alternative would be to shim the latch lower. You can't really see the shims if placed or painted correctly. That way you won't have to kill the hood for a good fit.
John
