Old 01-12-2006, 03:20 PM
stuffedfrog stuffedfrog is offline
Default Possible to (temporarily) link a 2-speed column shifter to TH400?
Yes I know it's absurd, but I just want to get the damn thing on the road after 17 years of not running. Spent all my money on engine/tranny/exhaust--just want to drive it for awhile and delve into the console/shifter later. Anyway, its a 1967 LeMans with shift on the column. Any hope?
Randall
Old 01-12-2006, 03:52 PM
bastereo bastereo is offline
i want to say that i dont have a lemans
but i would think that you could cobble something together, and just not be able to use the 1 st gear setting you should have
i would just make sure you get all the lever legnths correct so that when the shifter says drive the trans is actually all the way in drive, same with park and reverse and the rest
Old 01-12-2006, 03:54 PM
johnta1 johnta1 is online now
I think it would work, you just wouldn't have low or second on the tranny.
Drive would work along with reverse and park.
Old 01-12-2006, 04:36 PM
Oh man my 1st venture into the world of hotrodding without 1st gear??? Ok forget it, another month of work and more money I don't have. damn.
Old 01-12-2006, 05:07 PM
OK I'm being an idiot--just put it in Drive and let it go--just wont be able to shift through the gears myself.
Old 01-12-2006, 05:23 PM
Barrier Blue's Avatar
Barrier Blue Barrier Blue is offline
It worked for me.
When I'm paid, I always follow my job through...you know that.
http://www.youtube.com/watch?v=Al2b-...eature=related
Old 01-12-2006, 05:39 PM
Default been there, done that
The 2-speed linkage bolts right up to the TH400, the only gear you won't be able to grab manually would be first. No biggie, she'll drive just fine.
Old 01-12-2006, 06:22 PM
Half-Inch Stud's Avatar
Well sure. With the adjustment favoring Park, it might not reach the 1st gear slot on the TH400 internal detent.
b-man got there before me...I really ought to read the responses before responding.
Old 01-12-2006, 06:53 PM
stevep's Avatar
stevep stevep is offline
When we put a 389/ TH 400 in my friends 68 Lemans, the column shifter would go through all the gears. Low position was 2 and "below low" was 1. I guess if he had a shift indicator from a column shift 68 GTO, everything would have been perfect.
Old 01-12-2006, 07:47 PM
goatroper's Avatar
goatroper goatroper is offline
In my 67 with TH400 I can go through all the gears, and it started off as a 2 speed on the column. Drive is just as far a it will go to the right.
Old 01-12-2006, 09:26 PM
Karch Karch is offline
Worked for me...like B-man says, 1st binds some, but I had headers.
How many of you have driven over 340?
Old 01-13-2006, 05:18 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I put a TH 350 in my column-shifted '67 Cutlass convertible that originally had a 2 speed automatic. I have no problem manually shifting to all gears. (I just haven't found a bracket and linkage set that will let me connect the kickdown cable to my '67 Quadrajet throttle shaft, but that won't be a problem with a TH 400...)
Old 01-13-2006, 12:10 PM
Wow thanks for all the experience and support; its good to know every little problem I come across, there's been a hundred others been there first.
