Old 01-29-2006, 07:31 PM
pjdutton pjdutton is offline
Default 350 max rebore
Can anyone tell me what the max rebore is on a Pontiac 350 ?Also,are the rods the same as a 400?
Old 01-29-2006, 08:39 PM
cnc's Avatar
cnc cnc is offline
Not sure on the max bore but the rods are all the same except the 301 i believe 326-455 are the same if i'm wrong some one correct me
Old 01-29-2006, 08:55 PM
chiphead's Avatar
chiphead chiphead is offline
Max rebore on a P350 is .060 from stock bore of 3.875 would be 3.935", or 365 CID. All 326-455 engines had 6.625" long connecting rods. The 326-350-('66) 389-400 cranks are the same measurements too, but would require rebalancing to swap between engines.
Old 01-30-2006, 03:58 AM
greyno3's Avatar
greyno3 greyno3 is offline
Here's an article I found. Anyone know the results?
http://popularhotrodding.com/enginem...9PHREMPontiac/
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
Old 01-30-2006, 10:06 AM
bobzdar bobzdar is offline
Actually, a couple of people on CP cut up a couple of blocks and all of them appear to have the same overall wall thickness, so a 350 block in theory should be bore-able to around 4.12". I'm not sure if anyone has tried it yet, though, and core shift could cause problems.
http://classicalpontiac.com/qa7/disp...-+why+no+350?&
