Old 02-20-2006, 04:08 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
Default 64 DISC BRAKE CONVERSION
Old 02-20-2006, 05:38 PM
1963PONTIACKID 1963PONTIACKID is offline
thanks for the list! nice job, and sweet wheels too, i like those...
Old 02-20-2006, 06:45 PM
Fat Cat's Avatar
Fat Cat Fat Cat is offline
Out of curiosity, will this combo do the trick for a '66 Catalina?
"A bend in the road isn't the end of the road unless you fail to make the turn."
Old 02-20-2006, 07:13 PM
60man's Avatar
60man 60man is offline
Very nice job Jeff !!! I will probably snag a set of scarebirds kits just in case I need to switch from my 8 lugs to discs..
Thanks for all the info and pics on lower control arms.....I'm planning all ready.
Fat Cat: I'm not a 100% sure but you may be able to use some 67/68 stuff on your 65 !! Most parts break point is 59-64 & then 65 & up.....
ECM member.
MANDRA
Old 02-20-2006, 07:32 PM
Stuart's Avatar
Stuart Stuart is offline
What rotors are you using?
Old 02-20-2006, 07:50 PM
6T5 Cat's Avatar
6T5 Cat 6T5 Cat is offline
I think Scarebird has a setup for 65/66. You can do the Scarebird setup for less than what you would pay for a set of pontiac rotors, that is if you can find a set...nobody makes them anymore and the NOS rotors that show up on eBay every once in a while go for over $400.
[SIGPIC][/SIGPIC
Old 02-20-2006, 08:51 PM
wheelspin's Avatar
Thumbs up
Nice job Jeff, and thanks for the detailed pics and shopping list. Did you upgrade the rear brakes like you planned? Like Troy, I now have an alternative to my 8-lugs, although it would be tuff to get rid of them .
Les
Les Iden
Old 02-20-2006, 11:54 PM
JUDGGTO69's Avatar
JUDGGTO69 JUDGGTO69 is offline
looks goooood Pitt.........bet you like the way it stops too
Old 02-21-2006, 10:03 AM
63 Pontiac's Avatar
63 Pontiac 63 Pontiac is offline
Pitts, what size tires are you running on the fronts now? I have 235\75\15 all the way around which look like crap and scrub on turns, thinking 225\70's will fit\ride much better.
Old 02-21-2006, 11:05 AM
krautwolf's Avatar
krautwolf krautwolf is offline
Default Lug nut engagement depth
Pitt,
I'm reading step 7 of my Scarebird instructions. Apparently stock lug studs can be too short or have knurls that interefere with a flush rotot/hub fit. Did you have to replace studs or countersink/drill out the rotor side stud holes?
Old 02-21-2006, 12:46 PM
ponchopio ponchopio is offline
Jeff, this is the most comprehensive disc brake post ever! Outstanding work! May I put this in the Jeff Kalas section of the Full Size Pontiacs site?
John
www.fullsizepontiacs.com
Old 02-21-2006, 01:38 PM
perryka's Avatar
perryka perryka is offline
krautwolf,
I did the same conversion on my 62 Bonneville, and I did change out the wheel studs on the hubs. If memory serves, there was a recommendation in the instructions I got from Scarebird. Got 10 Dorman wheel studs and had them pressed in when the machine work was done on the hubs. It also gets rid of the left hand threads.
Old 02-21-2006, 06:27 PM
Norwegian Bonneville65's Avatar
Norwegian Bonneville65 Norwegian Bonneville65 is offline
Exclamation
Great thread,Pittsburgh..and an awsome looking car
In my humble opinion; This thread should be a "sticky" thread alongside the impeller thread in the cooling section !!
Moderator ??!!....
Stig
So let me get this straight....your engine is a 1.8 liter, while my Pepsi is 2?
Old 02-21-2006, 07:38 PM
Ziggy Ziggy is offline
Norwegian Bonneville65 "In my humble opinion; This thread should be a "sticky" thread alongside the impeller thread in the cooling section !!
Moderator ??!!...."
I can not agree more with you more , PITTS, you've done it again. This post should be rated higher!!!!!!! and bumped to the top and locked into a "fixed position".
Old 02-21-2006, 08:49 PM
6T5 Cat's Avatar
Jeff, did you use your stock power booster? I didn't see a booster mentioned in your parts list. Thanks
[SIGPIC][/SIGPIC
Old 02-21-2006, 10:08 PM
64catdroptop's Avatar
64catdroptop 64catdroptop is offline
Jeff,
A bit confused. It looks like a different motor in the last set of pictures you posted verses the first set... Have you got your new soup cans installed (8 to be exact)?
-r-
Never trust anything that bleeds for five days and won't die.
Old 04-04-2006, 09:47 PM
gregneun gregneun is offline
Default Disc brake conversion
I have a 64 GP. This weekend I found a 1974 Trans AM at the local Pick a Part. I took the Snowflake wheels, with spinners and the front brake set-up. The brake setup included spindles, calipers, rotors etc.
I originally was going to sell the brake set up on e-bay, but will they fit my car. I currently have 8 lug wheels.
I have the space saver tire listed on e-bay currently.
Any help would be appreciated, Thanks in advance.
Old 07-13-2006, 05:24 PM
Fat Cat's Avatar
Damn, where'd all the pics and part list go?!
Old 07-16-2007, 10:32 AM
mcduck mcduck is offline
Can someone update this? The first post no longer has a parts list or instructions. I'm trying to find out what parts I need to update a '63 Cat with manual drums to power disc brakes.
Old 07-16-2007, 06:13 PM
Guys contact Scarebird.
http://www.scarebird.com/7009.html
