Old 03-18-2006, 02:58 PM
Fullback66's Avatar
Fullback66 Fullback66 is offline
Default Time for new front disk brakes. What brand?
I think it is time for me to put on new front disk brakes. I think I would feel a lot safer driving in it.
Question:
What is a good brand for front disk brakes kit?
Did you do the work yourself? I would like to give it a try.
Would NAPA sell anything like that?
How much does it cost.
Is it the same bolt pattern as original drum brakes?
fb66
Old 03-18-2006, 08:44 PM
DBONES152's Avatar
DBONES152 DBONES152 is offline
Location: Illinois-Where Our Ex-Governors Make Our License Plates
Here's a good starting point for you.
http://www.stainlesssteelbrakes.com/products/search/
Old 03-19-2006, 02:31 AM
goatseeker's Avatar
goatseeker goatseeker is offline
I did mine myself using parts supplied by Ol' Pinion Head. The hardest part was the lines. Despite several attempts to get pre-bent lines I wound up fabricating all the lines myself. They have probably gotten the problems with line fitment worked out since I did mine.
You could get all the parts from a salvage yard if you have the time to look and probably do it for less than $500.
If you want a self contained kit I'd go with one from SSBC or MP Brakes.
Yes, the bolt pattern will be the same as long as you use GM style rotors.
Old 03-19-2006, 09:05 AM
Fullback66's Avatar
dbones, What kit do you get? The standard or the most expensive kit? I will only be driving the car. I will not be doing any extreme road racing.
I think I will go with a new kit and not one from a salvage yard. There are not a lot of good salvage yards aroung here.
fb
Old 03-19-2006, 10:08 AM
DBONES152's Avatar
FB,
I kinda pieced mine together - bought parts separate, fabricated brake lines, etc. From what I can see, SSBC (the link I orignally sent) has the complete kit. Our host also offers a kit. You should be able to do the work yourself.
I guess I would compare my set-up to the standard kit. I do not have power brakes, and I occasionally take the car down the track. It runs 12.2's and I haven't crashed thru the fence at the end of the track yet.
Dan
Old 03-19-2006, 10:19 AM
DBONES152's Avatar
FB,
One more thing - I'm not 100% sure, maybe someone else can jump in - but I think you need 15" rims on the car for disc brakes to clear. If you have 14"s better check first.
Old 03-19-2006, 10:38 AM
Fullback66's Avatar
I have 15" cragar ss rims. Did you put new bushings on while you did the brakes. I need new bushings also. This sounds like a good time to do it.
I only have a jack and jack stands. Is this all you used to do the work?
I do not have access to a auto lift.
Is there a good web site or book on how to do this process? Do the brake company you buy from have good instructions?
fb
Old 03-19-2006, 11:18 AM
retrojoe's Avatar
retrojoe retrojoe is offline
Stay away from The Right Stuff Detailing, they are sold through PY. I had nothing but problems with their kit and dealing with them. If you like parts that don't fit and you enjoy shipping parts back and forth several times, go ahead and use them! Oh yeah, they didn't supply any directions, not that men need them mind you....
"It beats pickin' cotton and waitin' to be forgotten"
Old 03-19-2006, 12:07 PM
DBONES152's Avatar
FB,
Nice Looking Car!! Never put 2 & 2 together that I was the one that asked you about the 15x8 Cragar with 5" backspacing.
Yes I did all the work with jackstands. Considering retrojoe's post, I think the smart thing for you to do is give SSBC a call and find out from them what kind of instructions and exactly what parts come with the kit.
Old 03-19-2006, 06:56 PM
Fullback66's Avatar
thanks for the advice.
Retrojoe, I saw the disk brakes in PY. I am glad you told me.
Bones, I think I have been hit in the head to many time. I thought I wrote you back before about the rims.
I think I will give ssbc a call before I order anything.
thanks
fb
Old 03-19-2006, 10:57 PM
goatless's Avatar
goatless goatless is offline
I used the SSBC kit on my '69. Their instructions were pretty good. I bent my own lines, which I think made the job easier. Almost everyone I've heard of that tried to use prebent lines on a conversion had to send them back or rebend themselves.
Yes, it is a great time to redo the whole front suspension, including bushings- it's almost all the way apart anyhow.
When I did mine I only had a gravel floored carport, so yes it is something that can be done with the car sitting on jackstands- just remember- SAFETY!
I would say the front disc conversion was the biggest improvement I've done as far as drivability.
1966 GTO
Old 03-20-2006, 02:23 AM
242177P's Avatar
242177P 242177P is offline
Lightbulb
Get in touch with Scarebird?
http://216.178.81.108/forums/member.php?userid=144435
Old 03-20-2006, 11:38 AM
bobbyj1's Avatar
bobbyj1 bobbyj1 is offline
I did both a fron suspension rebuild and a disc brake conversion last winter on my 67. I got the brake kit from ebay and the suspesnion stuff from perfomancesuspension.com. I did all work myself with the excpetion of taking the car to the local Midas to bleed my brakes and align the front end.
67 GTO Hardtop
Old 03-20-2006, 12:42 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
Originally Posted by DBONES152
FB,
yep, the repro dust sheilds apparantly will not clear 14" rims. They are also junk. buddy of mine was torquing down the upper mounting bolt and ripped the metal.
as far as instructions, if you don't have a chassis service manual, you shouldn't be doing work on your car. it will have everything you need pertaining to brakes, along with just about every other aspect of your car. get one, the price won't break the bank and you will learn something about your car
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 03-20-2006, 01:14 PM
fred kobbe fred kobbe is offline
Default 66 gto front disc brakes
the guys are right. i changed my 66 over and used a kit from lisbon bowtie in lisbon ohio. the entire kit was like $675.00. the instructions were good and they have a tech line that you can call and actually talk to someone that knows what you are referring to.i to ordered prebent stainless lines. this is a no no unless you have the body off,i had just put mine back on,so we sent them back and made our own.
yes,you definetly need 15" rims or the wheel will lock up on the caliper.i'm speaking from actual experience. however,the instructions told me this but as someone said instructions are not for men.
good luck
fred
spendin money havin fun gittin er done
Old 03-20-2006, 09:15 PM
rgto273 rgto273 is offline
I did mine myself with the car on jackstands. The kit i pieced together from NAPA as I went along. Do the front suspention bushings while you have everything apart. I just got a prebent line kit for a 67 GTO disk and had to swap two fittings, nothing major. I have 14 inch tires and everything fits, but you have about an 1/8 inch clearance
Old 03-22-2006, 07:55 AM
Fullback66's Avatar
Is there any modifing? Or, Is it a straight bolt off and bolt on without having to cut or drill any new holes?
fb66
Old 03-22-2006, 01:36 PM
Default 66 GTO DISC BRAKES
THE KIT I GOT FROM LISBON BOLTED RIGHT UP. THE ENTIRE CHANGE OVER INCLUDING THE MASTER CYL AND SPINDLES TOOK ABOUT 3 HRS.NO HOLES TO BE DRILLED ETC. I WILL SAY THAT IT WAS THE ONLY THING THAT DID BOLT RIGHT IN.
FRED
SPENDIN MONEY HAVIN FUN GITTIN ER DONE
Old 03-22-2006, 02:46 PM
Fullback66's Avatar
Fred,
Do you have a web site for Lisbon? Were did you get the brakes from?
fb66
Old 03-24-2006, 02:51 PM
bullheimer's Avatar
bullheimer bullheimer is offline
that would be nice. i live near scarebird and have heard great stuff. i was having second thoughts tho about using factory stuff but then remembered how awesome my 6000 pound truck stops now with 4wdb that are factory parts. i am going to go ahead and get the brackets from scarebird and then buy the rest at napa or where ever. my truck stops on a dime and my tempest should give back change. and it should be cheap cheap cheap.
ps. when i did my brake conversion i read to just saw/break off the protective "dust sheild" or whatever it is as it just collects crap. i have been running my truck off road in all kinds of crap and have never had an issue as disc brakes are self cleaning anyway. throw them away or dont waste your money buying them
I no longer have that beautiful 66 in my Avatar. whaaa!
When a cat is dropped it always lands on its feet. When buttered toast is dropped it always lands with the buttered side facing down. If a piece of buttered toast was attached to the back of a cat, when dropped, the cat/buttered toast combination should hover, spinning just above the ground, as it tries unsuccessfully to resolve the inevitable conflict of non-scientific certainties.
