Old 05-19-2006, 08:28 AM
bobbyj1's Avatar
bobbyj1 bobbyj1 is offline
Default WOW
Based on some recomendations from this board, I had Wayne Schicantek in Milwaukee WI rebuild the engine from my 67 GTO. I picked up the engine last week, installed it, and Wayne came down to my house to supervise the initial start up and fine tuning. Engine runs beautifully and Wayne is a pleasure to work with and does outstanding work. I would recommend him to anyone who is in need of engine work! My car has an entirely different personality. Mostly stock with some mild porting and polishing and roller rockers.
67 GTO Hardtop
Old 05-19-2006, 08:53 AM
grandville455's Avatar
grandville455 grandville455 is offline
Wayne rocks!!! Built mine almost 3 yrs ago and damn near 150- 200 passes down the strip and 5000+ miles till running tops!!!!!!!!!!!!!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 05-19-2006, 09:25 AM
pggto's Avatar
pggto pggto is offline
Does he specialize in Pontiacs?
Old 05-19-2006, 09:34 AM
bobbyj1's Avatar
Yes, he will build other engines but does build a lot of Pontiacs
67 GTO Hardtop
Old 05-19-2006, 10:27 AM
Blue1967GTO Blue1967GTO is offline
If it's not too personal of a question, can you share with us how much your rebuild cost? If you'd rather not say that's OK.
A friend of mine has his engine at Wayne's right now. He's paying ~$2500 for a basic rebuild and Wayne is supplying a set of heads for that price. His engine is being bored 0.040 over, new pistons, cam, bearings, etc. Reusing his crank and rods.
Old 05-19-2006, 10:43 AM
bobbyj1's Avatar
Mine was more than $2500 around $4000. I had porting and polishing done as well as a roller rockers which meant new pushrods, rocker studs. I supplied the heads but they required valve job, resurfacing, new valves and springs. I reused my crank and rods as well.
As I said Wayne is easy to work with and I was thrilled that he would drive 90 miles each way to supervise the initial start up!
67 GTO Hardtop
Old 05-19-2006, 10:54 AM
george kujanski's Avatar
Sounds like a test ride is required to verify the performance....
George
Old 05-19-2006, 11:55 AM
bobbyj1's Avatar
George
Will have everything back together very soon, dorve a littel yesterday without the fron grill or bumper! I will get you that ride soon!
67 GTO Hardtop
Old 05-19-2006, 02:39 PM
$4000 seems like a pretty reasonable price for that work. I'm leaning towards pulling my motor/trans this fall and having it all gone through. It had a budget rebuild years ago and there's really nothing wrong with it now but I feel like I could get more out of it and also feel more confident that it won't all explode when I hammer on it if it was redone by someone who knows what they are doing.
Old 05-19-2006, 07:32 PM
Formula8's Avatar
Formula8 Formula8 is offline
Wayne did my machine work and supplied me with a set of heads. His price was entirely reasonable and he is a great guy to work with. Everything was done on time and exactly to the price estimated beforehand. I would recommend Wayne to anyone.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 05-20-2006, 02:41 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
How about posting on the "Business Entities" forum about your satisfaction? Many of us read that forum to learn about good/bad experiences.
Just my two cents.
That's impressive- that your engine builder would travel to your place for start-up and tuning!
Old 05-21-2006, 09:40 AM
tempest455's Avatar
tempest455 tempest455 is offline
Wayne's done 3 engines for me. All good!
Tempest455
