Old 06-18-2006, 12:15 PM
John Payne's Avatar
John Payne John Payne is offline
Default Hurst Comp Plus Shifter Install
My 65 GTO 4 speed shifter/linkage is beginning to show its age (hanging up 2 to 3) which needless to say is killing my et's. I am considering going to a comp/plus setup and wonder if this will accomodate to a console .Any thoughts..?
Old 06-18-2006, 12:56 PM
jfmjr1 jfmjr1 is offline
I would first make sure your linkage is properly adjusted and possibly replace the plastic bushings where the linkage connects. Certainly easy and cheap to try it, otherwise have yours rebuilt or buy new or used comp plus. If youu have a console, you need to liely have yours rebuilt because shifter is specific for that application.
I also have a Comp plus that I removed from my 65 when I installed console and needed correct shifter to work properly. It's for sale if you need it.
John
Shifter pics
ID:	56388   Click image for larger version
ID:	56389   Click image for larger version
1965 GTO Clone 455 4 spd
1970 442 Convertible 455 auto A/C
Old 06-18-2006, 07:47 PM
John Payne's Avatar
Thanks for your suggestions..will check over tomorrow and also give Hurst a call.
Old 06-18-2006, 08:40 PM
Also contact Pete Serio on this board - he is THE master on Hurst Shifters - he literally wrote the book - and he rebuilds as well. His website is http://www.precisionpontiac.com/
John
Old 06-18-2006, 08:58 PM
John Payne's Avatar
Great info John..I will call Pete tomorrow.Thanks again for your help... John.
