Old 07-28-2006, 06:46 AM
gumbys goat's Avatar
gumbys goat gumbys goat is offline
Question Tire size Help Needed on 70 GTO[PLEASE]
I bought 16x7 and 16x8 rally 2s from wheel vintiques the backspacing is 4 1/2 for the rear and 4" for the fronts I only want To put Radial T/As on the car. What size tires will fit to fill the wheel wells up.
Old 07-28-2006, 11:11 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
You'd be doing your car and you a diservice with Radial TA's....those tires suck.
I'm guessing you'll only be driving it in the summer and fall and spring, and sometimes in the rain.
Check out survey results from Tire Rack.
http://www.tirerack.com/tires/survey...ireSearch=true
http://www.tirerack.com/tires/survey....jsp?type=HPAS
http://www.tirerack.com/tires/survey...y.jsp?type=UHP
I would say 245/50/16 would work well.
Old 07-28-2006, 11:26 AM
David Jones's Avatar
Jeezus.
Unless you spend all your time on a dragstrip or riding around in the snow, the T/A's are fine and have everything else covered looks wise.
Sadly, Radial T/A's aren't made in sizes that will work for the wheels you bought for your car.
Old 07-28-2006, 01:46 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
If your looking for rwl or blackwall? the only rwl bfg 16's are 265/60, 275/65 and 285/60 all of which are way to tall (28.5-30.1").
Old 07-28-2006, 06:39 PM
copper128 copper128 is offline
255/55-16's would be about the right size, but they're only available from a couple of manufacturers. No T/A's in a good size for 16's on your GTO
Old 07-28-2006, 11:24 PM
amcmike's Avatar
amcmike amcmike is offline
Probably 245/50 front, and 265/50 rear. You might be cutting it close with the 245s (measure, measure, measure), but your only other choice is 225, and that is mucher shorter than stock, so it might not look right.
When chosing rims and tires:
  1. Decide what brakes your using for your minimum rim. General rule of thumb brake rotor plus 4. Meaning if you have 13" brake rotors, a 17" rim should clear. Always verify with rim and brake manufacturers.
  2. Look at the tire height. Do you want them the same or staggered?
  3. Determine the maximum width tire that will fit. Assume around a 1/2" clearance on each side for suspension movement.
  4. Determine the availabilty of sizes that fit your needs. Best to pick a very popular size so that many choices are available should a tire brand discontinue that size. For example a 245/50/16 was production on many cars (80s-90s camaros, firebirds, etc). For example, a 305/40R16 once was available only through Michelin and was later discontinued.
  5. Starting with your existing rim and tire for baseline, determine what the new width and backspace is needed to get the tire placement correct.
  6. Some manufacturers only allow for 1/2" backspacing increments, so you may have to compromise tire location. Adjust your tire size accordingly. In other words, if you calculated needing 4.75" backspace and only 4.5" is available, you're pushing the tire out more and you'll need to pick a width that is about one or two sizes narrower to avoid rubbing.
Old 07-29-2006, 07:50 AM
Thanks everyone i called wheel vintiques and im returning the rims and there sending me the 15" rallys so T/As arnt good huh thanks for the input
Old 07-29-2006, 08:39 AM
Mr_GTO's Avatar
Why? I would keep the 16's the car will handle better.
Old 07-29-2006, 09:04 AM
True but i cant find white letter tires for the size i want
Old 07-29-2006, 09:26 AM
rknrl69 rknrl69 is offline
LOTS OF CHOICES WITH THE 15 IN RIMS.. OUR COMBO IS 15X7 WITH 4 IN BACK SPACE ON THE FRONT. TIRE SIZE 235X60X15. THE REARS ARE 15X8 WITH 4.5 BACK SPACE AND 275X60X15. IF I HAD TO DO AGAIN I WOULD DO WHAT YAKKER DID. PUT 275X50X15 ON THE BACK. WE PUT COOPER COBRAS ALL AROUND WITH RAISE WHITE LETTERS.
Old 07-29-2006, 09:35 AM
sounds good but wouldnt the combo yakker did make the front tires taller?
Old 07-29-2006, 11:47 AM
amcmike's Avatar
By .2". About the diameter of a toothpick. No one will ever notice. Done all the time.
Old 08-01-2006, 09:47 AM
Mr_GTO's Avatar
205/55SR16
Raised White Letters Serv. Desc: 89S Price: $109.00 (each)
Estimated Availability: In Stock
Qty: 1 2 3 4 5 6 7 8
Road Hazard Program: $52.32 total with four tire purchase
225/60SR16
Raised White Letters Serv. Desc: 97S Price: $103.00 (each)
Estimated Availability: Back Order
Road Hazard Program: $49.44 total with four tire purchase
235/55SR16
Raised White Letters Serv. Desc: 96S Price: $118.00 (each)
Estimated Availability: Low Stock
Old 08-01-2006, 09:48 AM
Mr_GTO's Avatar
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
Old 08-01-2006, 01:50 PM
Finally got my camera to work. Pics of our tires. 235x60x15 up front and 275x60x15 in the rear. Should have gone with a 275x50x15 in ther rear. The 60 is just too tall
ID:	60658   Click image for larger version
ID:	60659   Click image for larger version
Old 08-01-2006, 02:56 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
I have 275/50-15's on my lemans and they are about perfect.. if i had an aftermarker wheel with less backspacing, i could most likely go another inch or so wider. I had 275/60's on it before ,and like you just said, i think they were too tall, and i also like the 50's being about an inch wider than the 60's
Old 08-13-2006, 08:12 PM
I got the 15s and went with the 235s in the front and 275/ 50s in the rear on 8s and the fit was Purfect. Thanks alll who posted
Old 08-14-2006, 09:52 AM
Which tires did you choose?
Old 08-14-2006, 11:19 AM
amcmike's Avatar
I think we deserve some pics.
Old 08-14-2006, 02:05 PM
I would but im not sure how to upload pics it keeps telling me my pics are too big?
