Old 08-19-2006, 07:04 PM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Default How the heck do these go?
Front inner fender splash shields for 68-69 GTO. I have turned these every which way, and haven't found a fit yet. I don't know where on the wheel well they go, or even which end is up, or front ...
Could use some friendly advice. A pic of these items installed in your goat would be priceless.
Regards.
Bob Trimpe
Name:	wheel well seals.jpg
Old 08-19-2006, 09:50 PM
David Jones's Avatar
The rectangular ones go on the square cut outs on the inner fender above the upper control arms. Held in with some big staples. I've never replaced the others. They go in the inner fender (wheel side) frame contact area.
Old 08-20-2006, 10:49 AM
fyrebird68's Avatar
That takes care of one set of staple holes - thanks.
Anybody got any info on the odd-shaped piece?
Bob Trimpe
Old 08-20-2006, 11:29 AM
Yeah. My camera is on the blink or I could take a pic of it for you. It goes along the lower rear edge of the wheel house.
David says wheel side and I'm not going to argue that although mine are on the outside of the wheelhouse (cowl side).
At the rear of the wheelhouse, you'll see two holes that are nearly an inch in diameter. That wedge shaped cutout is an opening for the two holes. The lower hole is located near the curved apex of the cutout.
Beyond that, the shield pretty much follows the contour of the lower edge of the wheelhouse with the hole in the apex as the locator.
Don't know if that's clear or not. I'm going to look through my pics. I may have one in the pile that shows it in place.
Old 08-20-2006, 11:40 AM
Here you go....
Old 08-21-2006, 02:15 PM
fyrebird68's Avatar
So, it fits like this ... (pic). I was waaay off on guessing this one.
How much of the flap hangs below the edge of the wheelwell?
Thanks,
Bob Trimpe
Name:	wheel well seals 3.JPG
Old 08-21-2006, 07:29 PM
NO...One mistake. What you have labeled as "inner" is actually the outer. What you've got labeled "Engine compartment" is the outer. The narrow end that you have labeled "Outer" actually terminates at the opening for the upper control arm...Which is where the square shaped splash shield takes up.
Not very much of it hangs down. Maybe 2 to 3 inches in one area, none of it at all in others.
If you get that hole positioned in the cutout properly and get the narrow end in line with the edge of the control arm opening, you'll be in good shape.
Old 08-21-2006, 07:49 PM
Here's another pic of the same wheelhouse taken the same time from the front. You can see the splash guard at the top of the pic.
You can see that this is the driver's side wheelhouse.
Old 08-22-2006, 08:15 AM
fyrebird68's Avatar
Thanks, Greg. Pictures are just what I needed.
Regards,
Bob Trimpe
Old 08-25-2006, 11:01 PM
LPete LPete is offline
The seals at the rear of the skirts on my '69 are upside down compared to Greg's -- the large cutout faces down on mine. I'm sure they've never been off, but I can't promise they were installed correctly at the factory.
I'll try to get pictures in a day or two.
Old 08-26-2006, 09:46 AM
Originally Posted by LPete
I'm sure they've never been off, but I can't promise they were installed correctly at the factory..
Same here LOL!
Old 08-29-2006, 09:48 AM
fyrebird68's Avatar
Pete, have you had a chance to get pics?
Bob Trimpe
Old 08-29-2006, 11:54 AM
Bob Trimpe
Sorry about the delay... too many irons in the fire.
This is one side (I took the seals of the other side already, but they were mounted the same way). Hopefully these will help -- let me know if you need a different shot.
Lee
ID:	63632   Click image for larger version
ID:	63633   Click image for larger version
Old 08-29-2006, 12:47 PM
fyrebird68's Avatar
Wow, two opposite replies from two credible sources, looking at two cars that have obviously been together a long time.
Thanks for taking the time to research and photograph, guys. At least I know which part of the well they go on. Let you know if I come across any more info on these.
Regards,
Bob Trimpe
Old 08-29-2006, 02:37 PM
I'm sure Greg's are wrong.
I don't have most of my car here at the moment, so I can't tell how the seals fit and why the cutouts are where they are. I'll hopefully be putting it back together in the next few weeks, so I'll let you know if I come up with anything.
I wonder if the factory assembly manual has anything? I'll look there, too.
Old 08-29-2006, 05:10 PM
aitstra's Avatar
aitstra aitstra is offline
Mine are like LPete's. They look correct on the car because the tab forms a little mud flap behind the front tire, just behind the metal "tab" haning down. There was only one set of staple holes.
"Sure honey, you can park in the garage this winter."
Old 08-29-2006, 06:04 PM
I really can't tolerate being wrong so I'm sure I'm right.
Old 09-01-2006, 11:56 PM
68GTOJoe 68GTOJoe is offline
Default Inner Fender Seals
Hey guys,
I have an original factory install (all be it in horrible shape) and sorry to say Greg, but this is one of those rare instances where you were wrong. Since LPete's is the same as mine, I declare majority rule.
Now...I have to staple new seals to my newly restored inners - so how in the world do you staple them? I bought repop seals with staples. What would you/have you guys used? This may sound silly, but I don't feel like ruining all my hard work. Thanks for any help!
-Joe
ID:	64033   Click image for larger version
Old 09-02-2006, 01:48 AM
Wink
Well, I guess it had to happen sometime. I'm almost 50 years old now and that's the first time I've ever been (suspected of being) wrong.
Old 09-02-2006, 09:49 AM
I'd blame it on age.
I'm 46 and just learning to use that excuse. Like they say, I thought I was wrong once, but I was mistaken.
Have a great weekend!
