Old 09-03-2006, 06:40 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default What kind of webbing is this 400
OK guys is this average,weak or good main webbing for a 400? Looks average to me, but I didn't have another block to compare with.
ID:	64171   Click image for larger version
ID:	64172   Click image for larger version
Old 09-03-2006, 08:21 PM
KS circutguy's Avatar
Looks to me to be the thick version.
Old 09-03-2006, 08:33 PM
Brian Baker's Avatar
Looks like a great candidate for 4-bolt splayed caps. Got any pics of the lifter valley?
Old 09-03-2006, 09:34 PM
Skip Fix's Avatar
I'll get some tomorrow Brian.
Old 09-04-2006, 07:46 AM
mysticmissle's Avatar
what is in the lifter valley that differentiates block to block? thanks Brian
Old 09-04-2006, 09:00 AM
PONTIAC DUDE's Avatar
Cool Sorry but...........
looks to be the thin casting block. support under the main caps in the area under the cylinder bore. Pics are too far away. Need pics closer to the cap mate area under the cylinders in #2. 3 & 4.
I have found 4 basic 400 casting blocks. Need to take pics before I build and sell them all to customers and put on my website?
What's the date code by the distributor.
From what I see it would be good for a bacic 455 conversion with a mild cam or a 350/375 hp 400 combo.
Old 09-04-2006, 09:02 AM
Talking
That works for the 455 blocks and still have to check other ares on the 455's. But if Brian tells, I'll have to kill him. LOL.
Old 09-04-2006, 09:59 AM
Skip Fix's Avatar
I'll take some closer, but you can see the #2 main cap front and back side area.
Old 09-04-2006, 10:32 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
It has less meat in the main webbing area than a 68 block or a 72 junk block I have laying around. I you look at the first pic you posted, you can see a 'step' where the cylinder ends, toward the middle of the block. Neither of mine have that but have metal there.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 09-04-2006, 12:19 PM
birdzz birdzz is offline
P-dude, I have a thin web 400 I was considering installing your stroking kit on, so I take it that it works fine? I would be looking for substantially more than 375 horses, though!
Is it possible to weld it up for more strength?
Old 09-04-2006, 01:50 PM
Skip Fix's Avatar
Here's closer Ken
ID:	64228   Click image for larger version
ID:	64229   Click image for larger version
ID:	64230   Click image for larger version
ID:	64231   Click image for larger version
Old 09-04-2006, 01:52 PM
Skip Fix's Avatar
Jeff can you snap a picture?
here's lifter valley on a 72 HO block
Old 09-04-2006, 02:31 PM
Post
I wouldn't recommend that block for any higher hp applications. No support under the cylinder bore to the pan rail. But for a mild rebuild as i stated above shouldn't be an issue.
birdzz:
I wouldn't do the 4.250 deal with that block. But a 455 conversion with 9.0-1 compression, under 375hp and 5200 rpm won't be a problem.
FWIW: You can run real low 13's making 350/375 hp in basically stock chassis car.
Just bottom fill the block, deburr the block, ARP studs and have the line bore checked.
Old 09-04-2006, 05:05 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Dude, you may have just solved some of my problems with the mains on my sprint boat
All centred around #2 which looks like where Skips pic was taken. My block looks the same in this area. Using factory mounts at the front (either side of #2) the mains were moving around alot and cracked the cap outboard of the dowel on this side
Can you confirm if the "thicker" blocks have more material along the pan rail (shown "A" on my marked up version of Skips pic) Mine has "bosses" for the mount holes as per the pic also which wouldnt be visible if there were more meat there. I know the 58 etc blocks have more meat here and are looking for one here for a new boat engine build as we dont need a starter mount or any factory side mounts
Also does area "B" differ ? My current block (73 YT code) appears a little thicker here ?
Any help figuring this out would be great
Working on going faster (and now staying dry at the same time !!)
Old 09-04-2006, 05:09 PM
455-4+1's Avatar
Forgot to post pic (cheers Skip)
Old 09-04-2006, 05:49 PM
Skip Fix's Avatar
I was thinking the B area was the area toi lok at. Although I had a 70 block that to me didn't look much different, and the caps actually looked thinner to me.
My 72 455 block is on a roll araound with a pan so I can't look at it.
Anyone else got block pics??
Old 09-04-2006, 06:27 PM
SergeF SergeF is offline
Here are some pics from my spare 67 400 block. How is that look?
ID:	64255   Click image for larger version
ID:	64256   Click image for larger version
ID:	64257   Click image for larger version
Old 09-04-2006, 06:42 PM
Skip Fix's Avatar
OK to me the 67 has meat all the way to the dowel whereas this block is just to the bolt area. The rails are thicker under the bore but I would think the main cap area is the more important area. Kins of subtle differences.
Old 09-04-2006, 07:01 PM
Skip, I also have 2 70 blocks at my dad's house. If you want I can get pics later on. To me, I really dont see much difference.
Old 09-04-2006, 08:12 PM
455-4+1's Avatar
Definitly alot more meat along the pan rail below the bore in the 67 block compared to my 73 YT block (area "A")
On mine the bosses for the motor mount holes show up clearly and the rail is thinner
Hmmmmmmmmm
