Old 09-12-2006, 10:15 PM
Johnny GTO's Avatar
Johnny GTO Johnny GTO is offline
Question Spraying Chassis Saver on firewall
Has anyone ever sprayed Chassis Saver to their firewall before. Don't know if will peel on smooth metal?
Old 09-13-2006, 01:15 AM
CDJr's Avatar
CDJr CDJr is offline
I sprayed mine with it, but I havent dropped the motor in it yet. If I remember correctly, I scuffed it pretty good before I coated it since I had it stripped down to bare metal.
A friend will help you move...a GOOD friend will help you move a body.
Old 09-13-2006, 02:41 PM
Johnny GTO's Avatar
thanks CDJr, I lost my nerve to shot it. I shot it with epoxy primer instead.
Old 09-13-2006, 09:43 PM
CDJr's Avatar
Well, for future reference, remember that that stuff will stick to rougher surfaces for sure...the rougher the better. From my experiences with it, the more you prep and/or clean a surface prior to coating it, the less it will adhere. I know that sounds bass-ackwards, but thats the conclusion I came to after experimenting with it. For peace of mind, Id suggest you find some scrap steel thats rusting/corroding/flaking in varying degrees, and experiment with it. I did this using a foam brush to slop it on stuff using whatever was leftover in my paint gun, just to see whatd happen lol.
