Old 12-21-2006, 08:30 PM
bikerdaveandjenn bikerdaveandjenn is offline
Default weight X HP = ET
is there a basic formula for this?
Dave
Old 12-21-2006, 08:37 PM
BILTIT's Avatar
BILTIT BILTIT is offline
http://www.wallaceracing.com/et-hp-mph.php
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 12-21-2006, 09:45 PM
455earlybird's Avatar
455earlybird 455earlybird is offline
My 60 foot time show me having 937 HP!! I wish!!
67 Firebird Best time 1.53 60' [email protected] 1/4 [email protected] 1/8 3500lb. leaf springs
Old 12-21-2006, 10:21 PM
johnta1 johnta1 is online now
HP from ET (1/4 mile) = WEIGHT * (5.825/ET)^3 is the standard accepted equation.
455earlybird, I need to double check that page.
I think it might be for the time to get to 60 mph, instead of 60' time.
I'll double check it.
Old 12-21-2006, 11:26 PM
455earlybird, try it again and see what it is.
Old 12-21-2006, 11:35 PM
BILTIT's Avatar
350HP, are u sure it isn't on the low side now? Darnit!
Derek B.
Old 12-21-2006, 11:52 PM
Goat-Racer's Avatar
Goat-Racer Goat-Racer is offline
Seems pretty darned accurate to me. It's probably one of the most conservative calculators iv'e seen online, and probably one of the most realistic.
My mph indicates 610 fwhp.
My ET indicates 640 fwhp.
My 60' (1.44) indicates 633 fwhp.
Brian Rock
'65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs.
9.88 @ 134 N/A on Cali 91 octane.
http://www.youtube.com/watch?v=NJEIY5OJ68g
Old 12-22-2006, 12:17 AM
red76TA's Avatar
red76TA red76TA is offline
damn your is front wheel drive? - those are pretty nice numbers
Old 12-22-2006, 02:56 AM
XSIVPWR's Avatar
XSIVPWR XSIVPWR is offline
WOW I just put the hp#s of my old motor and the weight of my car and this calculator is real close.
Old 12-22-2006, 09:15 AM
Goat-Racer's Avatar
Only when I launch in reverse!
Brian Rock
Old 12-22-2006, 09:46 AM
John Langer's Avatar
John Langer John Langer is offline
I haven't seen any calculators on any web site that were accurate. On the other hand, the $8 Moroso slide rule is DEAD ON. I run within .05 of what it says every year after performance upgrades as well as a few others that have had their motors dyno'ed at BES. Now if you get your motor pumped on one of those happy dynos, all is out the window.
Old 12-22-2006, 12:32 PM
Half-Inch Stud's Avatar
HP from MPH
355HP from 103MPH High12's
426HP from 112.4MPH lowest 12's
497HP from 123MPH lowest 11's
4xxHP from 11xMPH to-be-determined
5xxHP from 1xxMPH to-be-determined
Old 12-22-2006, 01:10 PM
John what are your ET/Weight stats and what is your HP?
Old 12-22-2006, 04:41 PM
SLICK1 SLICK1 is offline
Arrow
Originally Posted by John Langer
I haven't seen any calculators on any web site that were accurate. On the other hand, he $8 Moroso slide rule is DEAD ON. I run within .05 of what it says every year after performance upgrades as well as a few others that have had their motors dyno'ed at BES. Now if you get your motor pumped on one of those happy dynos, all is out the window.
GOOD TO HEAR! I GET THE SAME RESULTS BUT WALLACERACING IS PRETTY GOOD UNTIL I PUT IN MY 60ft TIMES TOO?: I WISH I HAD THAT POWER.
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 12-22-2006, 04:57 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
BILTIT a 350 RWHP means you are making 455+ HP at the flexplate! Using a driveline loss of 23% shows the 455hp. Not to shabby!
WOW, it is amazingly accurate in my combo!
*Your ET / MPH computed from your vehicle weight of 3250 pounds and HP of 321 is 12.60 seconds and MPH of 106.32 MPH.
*Your Horsepower computed from your vehicle weight of 3250 pounds and MPH of 106.54 is 323.03. (106.54 was the best MPH last season)
*Your HP is 321.11 computed from your vehicle weight of 3250 pounds and ET of 12.60 seconds
BUT, my ET and MPH are not optimized as evident by my best 60' of 1.864 and the engine nosing over at the top of 3rd gear! It will be interesting to see what it shows when I run the car next Spring.
It shows my current FWHP is 417 which sounds cool. But with the new intake, 1/2 fuel line, and 3500 converter it should make a marked improvement! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Old 12-22-2006, 05:36 PM
Thumbs up
HEY BRO, HOW YOU BEEN? & HAPPY HOLIDAYS TO YOU AND YOURS!
Now on to the topic at hand! I must point out, (AND Mr. JOHN LANGERS WILL AGREE) These calculators and the moroso power speed calculators work their best when you totally have your suspension sorted out and are hooking well for your E.T. & M.P.H.!!!! Otherwise you're just spinning your wheels so to speak and won't get actual hard core data to go on!!! SO MAKE A PRIORITY TO GET THAT POWER TO THE GROUND FIRST AND FOREMOST!!!
(see it in action)
Old 12-22-2006, 06:19 PM
3250lbs [email protected], how much hp did I make???
Old 12-22-2006, 06:39 PM
Your HP computed from your vehicle ET is 905.74 rear wheel HP and 1,006.38 flywheel HP.
Your HP computed from your vehicle MPH is 805.55 rear wheel HP and 895.06 flywheel HP.
This is probably the minimal HP if the car is set up right.
This is just using the 3 inputs. No cd of the car,gears,converter,head flow,etc.
Old 12-22-2006, 06:46 PM
So what does your calculator say if a motor makes 976 hp and weighs 3250?
Old 12-22-2006, 06:49 PM
Motor Daddy Motor Daddy is offline
Did you stay at a fixed RPM the entire 1320?
