Old 02-28-2007, 03:08 PM
6T9GTO's Avatar
6T9GTO 6T9GTO is offline
Question Painting Advice
Not a Pontiac fender, but....
I have purchased a couple of new fenders for my Jeep CJ7. They have the black pimer (e-coat?) on them. Do I need to sand this stuff completely off then re-prime? Or do I need to scuff it, them prime over that before painting? Or do I need to scuff the ecoat and paint right over that?
Thanks in Advance,
Bill
Old 02-28-2007, 03:27 PM
RARON455's Avatar
RARON455 RARON455 is offline
I have never heard that it needed to be sanded off I have always heard that the primer is a good rust inhibiter, may want to rough it up and spray your choice of primer I am a very strong believer that you want to use the same kind of primer and paint if you can. hope this helps
Old 03-02-2007, 10:03 AM
Leave the e-coat. You have a multiple choice regarding paint proceedure.
You "CAN" scuff the e-coat with a red scotch brite and paint right over it, but not best choice. Cheapskate method.
Normally - shops scuff the e-coat with a red scotch, remove imperfections with some 220 or 320 paper, then use a non-sanding primer sealer, then follow with selected paint products.
"BEST" and most expensive, you can sand e-coat then follow with a catalyzed primer surfacer. Wait a day, sand again, begin selected paint process(es).
I'm guessing you are going to paint it entirely before installing it. If not - at least paint the jambs before installing.
Old 03-02-2007, 07:53 PM
400 4spd.'s Avatar
What he said.
Old 03-03-2007, 10:44 AM
6T9GTO's Avatar
Thanks for the replies, guys. Probably will go with the non-sanding primer. The fenders will be the best part of the Jeep at this point of the build-up.
-Bill
