Old 03-08-2007, 08:17 PM
BLUE 78 TA BLUE 78 TA is offline
Default 78 TA carb
I am in the process of strocking my 400 with alot of $$$$$$ go fast parts from BUTLER. I went with a aluminum intake and was told that I should go with an early 70's carb to get rid of the smog junk. Would this be worthwhile or just keep what I have? Thanks
Old 03-08-2007, 08:48 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
After reworking the idle circuits Cliff Ruggles prefers the late models.
Old 03-08-2007, 09:13 PM
Larry Navarro's Avatar
Use what you have. In my opinion they are a better carb as far as the range of tuning ability. They also feature a part throttle adjustment that the early carbs don't.
Old 03-08-2007, 09:25 PM
Great thanks. How would you go about tunning it. It will have alot more horsepower than factory. Thanks again
Old 03-09-2007, 12:46 AM
Grand73Am Grand73Am is offline
Recommend the book, "How to rebuild and modify Rochester Quadrajet carburetors" by Cliff Ruggles. Great explanations and photos.
Old 03-09-2007, 07:37 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
Personally, I think its worth the money to have a guy like Cliff set up your carb. There is a guy like Cliff here in Green Bay, that set up the quadrajet for my 68. He used all the specs of my engine, & has all the right equipment to set it up right. That engine could not run better. From what I understand, the carbs are fussy about vacuum, but when they are set up right for your engine, they are fantastic. I think the term "quadrajunk" came from people that never got them right.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 03-09-2007, 08:26 AM
Default carb
Thanks I will check it out. Thank you for the help. That sounds like I need to do that.
