Old 03-13-2007, 08:48 PM
63pontiacgp's Avatar
63pontiacgp 63pontiacgp is offline
Default Been Awhile
Hi all
Been absent as of late. Just installed a beefier front sway bar, a rear sway bar from Fabcraft and the tubular uppper and lower rear control arms from Ramair. The car rides like a dream. Been thinking about converting my rear end to a Safe-T-Track. Is it pretty straight forward and what do I need to look for?
Mike
Old 03-13-2007, 09:06 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Just need to find one in the ratio that suits you. Very easy swap. You will need a slide hammer to remove the rear axles. Pull them out, then remove entire hogs head/3rd member/pumpkin. Comes out, & if it does not crush you, you put your replacement in. Not the easiest things to find, but they are out there. Check with Indiana Pontiacs & see if he has some.
I like 3.08. Good hwy and street combo I think. I have 3.42, & with a 3 spd auto you just run too high RPM on the Hwy. for a longer trip. Have a 3.23 but have not tried that yet. 2.73 is OK but probably a little to high for a GP.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 03-13-2007, 09:12 PM
Hitman's Avatar
Hitman Hitman is offline
I wish mine was a 3.08, that would make a world of difference. I'm stuck for now with a 2.41 posi. It works but that will be the first performance upgrade.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 03-13-2007, 11:41 PM
T.Weber's Avatar
T.Weber T.Weber is offline
Smile
A trick for removing the rear axels if you don't have a slide hammer or want to mess with one is
1) remove wheel
2) remove brake drum
3) remove 4 nuts that attach wheel bearing retainer
4) install brake drum back on the axel backwards
5) install wheel stud nuts loose as possible
6) use brake drum as slide hammer
I have used this method many, many times and it is actually faster and easier than using a slide hammer to pull the axels. I was taught this by an "old timer" years ago. Funny now I'm an old timer.
Old 03-14-2007, 06:41 PM
ho421's Avatar
ho421 ho421 is offline
Mike, who did you pick up your swaybar from. When I restored my frame and suspension, I tried installing one of those beefy swaybars sold thru PST. After three weeks of fighting it, I gave up. The fit wasn't even close. PST staff were nice enough to send a return shipping label and a 25.00 coupon for my troubles.
Old 03-15-2007, 07:14 AM
The front bar I ordered through Summit, the rear from Fabcraft via eBay.
Old 03-15-2007, 07:15 AM
I forgot to mention, I initially had one of the rear bars from PST that went between the control arms forward of the rear end. It did not look or feel right.
