Old 05-07-2007, 11:11 PM
rod cole rod cole is offline
Default seperating trans from rearend?
trying to remove the autotrans section from rearend for just jay. The torque tube had 6 bolts removed torque tube Then removed cap on torque conv. removed wire ring removed conv. Then removed 4 bolts holding aluminum part to rear section. Now it is loose rotationally but wont seperate before trying force? clip or something im missing? thanks Rod
Old 05-08-2007, 01:46 AM
mechanickeith's Avatar
Cant remember if you have to remove the speedo drive or the governor?? 1 or both have to come out. The tech manual is not real clear on this. After much reading through 3 different tech manuals, pull the governor out of the trans!!
Old 05-08-2007, 08:37 AM
jusjay's Avatar
jusjay jusjay is offline
Try Ken at East West Auto, He will know 1-800-447-2886
Thanks for trying Rod.
Old 05-08-2007, 09:51 PM
Default seperating
thanks mechanickieth removing the govener allowed it to slide right apart no force nessecary. thanks again. Rod
