Old 05-10-2007, 01:26 PM
JAMES H. BLOOM JAMES H. BLOOM is offline
Question 66 VENTURA DISC CONVERSION
HI GUYS; I AM A FIRST TIMER ON THE FORUM, I HAVE A 66 2DR. VENTURA, 389 2BBL . I AM INSTALLING A 400 WITH TRI-POWER. MY BIG PROBLEM IS THE BRAKES. I WANT TO CONVERT TO FRONT DISC, BUT NONE OF THE CONVERSION SHOPS CARRY KITS FOR BIG BODY PONTIACS. DOES ANYONE KNOW OF ANY SHOPS THAT CARRY THE CONVERSION KITS FOR A 66 PONTIAC AUTO TRANS CAR. OR HAS A TRIED AND TRUE COMPLETE LIST OF THE PARTS AND YEARS OF PARTS TO DO A BONEYARD CONVERSION? ANY AND ALL HELP WILL BE APPRECIATED
Old 05-10-2007, 02:45 PM
Stuart's Avatar
Stuart Stuart is offline
You can swap in disk brakes from a 69-70 full size Pontiac if you can find them, the problem there is the rotors are nearly impossible to find new. The most popular choice these days is using one of Scarebird's disk brake kits: http://www.scarebird.com/12802/21632.html
Do a search in this forum, there have been numerous discussions on this kit and I believe there are some photos of the installation as well.
Old 05-10-2007, 02:47 PM
carmak's Avatar
carmak carmak is offline
One option is to use 69/70 full size Pontiac disk brake spindle assemblies. Use the master and proportioning valve for a 69/70 full size disk brake also. It's all bolt on. As of 5 years ago the rotors and calipers were available new.
Disk brakes were fairly common on 69/70 full size Pontiacs. Look for Bonnevilles as almost all of then are disk cars.
Good luck!
Carmak
Riverside, Iowa
Old 05-10-2007, 02:49 PM
carmak's Avatar
OK. Stuart can type faster and has more up to date info on the rotor availability.
I have a friend that used a scarebird conversion on a Mopar and was very pleased with the results.
Carmak
Old 05-10-2007, 05:04 PM
Fat Cat's Avatar
Fat Cat Fat Cat is offline
Those two pretty much summed it up. If you're interested, I'm thinking about selling my Scarebird brackets....
"A bend in the road isn't the end of the road unless you fail to make the turn."
Old 05-10-2007, 05:18 PM
MY UNDYING THANKS TO STUART,CARMAK,AND FATCAT. THANK YOU FOR ALL THE INFORMATION. I WILL KEEP YOU POSTED ON MY PROGRESS!!!!!!!JAMES
Old 05-10-2007, 09:47 PM
Stuart's Avatar
There's a description of the 69-70 disk brake swap over on the Full Size Pontiac Club website, at http://www.fullsizepontiacs.com/fsptech.htm. The swap is being done on a 61-62 big car, but the procedure would be pretty much the same for a '66.
Old 05-15-2007, 11:47 AM
presidential's Avatar
presidential presidential is offline
Send a message via AIM to presidential
If you're serious, lemme know.
~Craig
1964 Catalina 455 - It's ALIVE!
Old 05-20-2007, 01:01 PM
Fat Cat's Avatar
Craig - sent you a PM about those brackets.
-Steve
