Old 05-23-2007, 11:22 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
Default roll on paint? " the $98 paint job " HOT ROD MAG july 07
who has read this and who thinks its worth a try?
please read and tell me, i think i might do this so that i can have at least something rather than PRIMER.
OZ
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-24-2007, 02:33 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
I read it.....got the mag in the mail the other day. Its pretty interesting, sounds like a lot of work.
Here is a basic rundown.........
They used Rustoleum Stops Rust (quart cans, not spray cans) and rolled it on using the high density foam rollers. They mixed it roughly 50%-60% paint and 40%-50% thinner............consistency of whole milk or a little thicker. Roll on one coat....looks like crap, some runs and a lot of little bubbles. You can use low air pressure, blowing on it or whatever to get rid of the bubbles. The first coat must dry before adding coat #2. Then you wet sand with 600 grit to get all of the imperfections out because there will be some small runs etc. Then you repeat......2 more coats then wet sand.......then again with 2 coats and wet sand. Repeat the process until you have ample coverage....could be 6 coats could be 10.......they used 6 coats total. After the final coat wet sand with 600 grit and then with 1500 grit. After that you have to buff and polish it out.
Pros.....
cheap
minimal safety equipment
no need for spray booth
easy cleanup
easy way for your kids to help
good conversation later
easy to touch up
Cons......
time consuming
labor intensive
only a basic enamel finish
no metallic colors
Im going to try it myself just to see the result. Im just going to try it on a small piece of sheet metal.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 05-24-2007, 02:34 AM
Colin's Avatar
Oh......EACH coat must be dry before you apply the next coat. Can recommends 24 hours.
Duplicolor has a new system out.......a laquer I believe. Ready to use right out of the can, supposed to be fairly easy for the DIY people. They have the primer, paint and clear. Its available at most parts stores like Autozone, Advance etc. Advance has it for $19 per quart......and there are some decent colors. I may end up trying that as well.
Here is a link http://duplicolor.com/products/paintshop.html
They have an e-learning video too.......I have not watched it yet.
Im curious about the roll on deal........Im going to use an old fender I have in the shop and try it. If anyone is interested I will start a new post in the Body SHop section. I will post the steps and pics of each step as I go. Since the paint has to dry for 24 hrs between coats it will be a LONG process. I figure I will do a coat each day after work.......so it will be 2 days of paint and a day of wet sanding times 3 or maybe times 4 depending on how many coats I will need to use for ample coverage.
Old 05-24-2007, 07:10 AM
im down because i think i might go this route. at least i wont have the ugly primer look. it will make the car look as if it has a paint job, but that is like 10 years old an needs to be redone. thas ok with me.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-24-2007, 07:16 AM
Jeffzilla's Avatar
Jeffzilla Jeffzilla is offline
A factory paint job is about 1.5 to 2.0 mils. The roll on stuff sounds like it would be very thick, which could lead to cracking and crazing on down the line............
11:89 @ 111.11
Old 05-24-2007, 07:17 AM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
never paint a car with a brush and roller.
Old 05-24-2007, 07:49 AM
matt1970pon matt1970pon is offline
I open to anything.If you wet sand it you can make anything smooth.I painted my car myself never did before.I just used a sears cheapy gun.Painted mine polar white.Just don't try to spray a metellic the first time you paint.If you use a solid color and the block sand it,it looks great.The paint from PPG was 160 total.It was a one part paint,no clear.It beats driving with primer.
Old 05-24-2007, 08:44 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
If you guys read on the thread over on Moparts, alot of them are using Brightside boat paint, the gloss qualities are better with less work.
Old 05-24-2007, 11:42 AM
Bill, i went on the website, i guess im to dumb to figure it out, but i couldnt find it, could you please post a link. Thanks
Hey Colin, can you do a dark color rather than white.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-24-2007, 12:58 PM
TTAJay's Avatar
TTAJay TTAJay is offline
I've been reading that thread for about a year. I can't wait to try it on one of my projects. If you read through all the posts at once it will take about 24 hours of time.
Here's the original thread that started the whole movement:
http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
The thread got so big they had to divide it up. Here's part 2:
Here's part 3 with the most recent posts:
http://board.moparts.org/ubbthreads/...0&fpart=3&vc=1
Here's a couple of links by people on these threads that copies all the good info out and put it in their own sites:
http://www.rollyourcar.com/
http://carpainting.wetpaint.com/
Jason Stanco
Albany, N.Y.
Former owner of '89 TTA #1102
Too Many cars... so little time
'74 455 TA
'76 455 TA
'77 400 TA
'79 400 TA
'30 Model A Tudor
Old 05-24-2007, 06:02 PM
http://board.moparts.org/ubbthreads/...ue#Post3477380
check out this guys 69 mach 1 sick black satin paint
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-24-2007, 09:21 PM
hectore3 hectore3 is offline
As everybody knows paint and bodywork are by far the most expensive steps in a restoration. Guys like me who just have a daily driver are down for this type of thing. And really how bad can it be? Henry Ford painted millions of Model T's and A's with a roller too.
Old 05-24-2007, 09:38 PM
I may just skip the Rustoleum and Brightside and go to Tractor supply and get some tractor paint. They have over 20 differant colors. I'll stay away from the J.D. green for sure.
Old 05-25-2007, 03:20 AM
Colin's Avatar
I will probably use dark grey.
Old 05-25-2007, 07:09 AM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
By the way, I read some other magazine article, right before the one with the guy using a roller and rusty paint who used brushes and a special paint. Something about a tractor paint and wet sanding it which looked really pretty nice when he was done. Where is this article? I've been looking for it since the day after I read it. Anyone know which one I mean??? Thanks.. Mike
Build it fast, build it right, hold On TIGHT !!!
Old 05-30-2007, 05:54 PM
tempest455's Avatar
tempest455 tempest455 is offline
Some street rods and '55 Chevy's look good in suede!
Tempest455
Old 05-30-2007, 09:58 PM
zbuickman's Avatar
zbuickman zbuickman is offline
Stop it I resemble that remark!!!!!! seriously I did that when I was a kid. painted my Sprint with tractor paint. took FOREVER to harden up. Case gray IIRC. That roller thing has been going around the internet for a few years now.
Brent
65 "X"vert
84 T-Type
my cars
Old 05-30-2007, 10:17 PM
zbuickman's Avatar
A buick guy did his BLACK GNhttp://www.turbobuicks.com/forums/bu...tml#post483278
Brent
65 "X"vert
84 T-Type
my cars
Old 05-31-2007, 06:17 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
OZ
Primer all the way!
Old 05-31-2007, 09:36 PM
YVEYANT's Avatar
YVEYANT YVEYANT is offline
Send a message via AIM to YVEYANT
I don't want to say the painting is the easy part, but compared to the body work it is. If any of you guys are going to do this, put a lot of time & attention into smoothing out your panels first. What you were able to hide with low luster/flat primer will stand out like a sore thumb with high gloss paint. The more shine you have the more imperfections you will see.
That Buick looks very good considering.
Ant
1967 Pontiac Tempest, GTO-Inspired
"What's so special about having Italian food cooked by a bunch of friggin Mexicans"
Paulie-
Rocky Balboa
"Your heart is free, have the courage to follow it"
Braveheart
http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg
