Old 06-24-2007, 12:14 PM
Trucker73 Trucker73 is offline
Default 64 326 points
What is the proper setting for points on a 64 326 tempest? I have never had a car with points before so its all new to me.
Old 06-24-2007, 12:45 PM
engineer engineer is offline
use dwell meter and adjust to 28-30 degrees.
Old 06-24-2007, 07:32 PM
Thanks for that info but i dont have a dwell meter.
Old 06-24-2007, 08:35 PM
jarhead's Avatar
jarhead jarhead is offline
With a feeler gauge set them to .013 - .019. GM engines with points have the benefit of being able to set the points with a dwell gauge with the car running. That's what the trap door is in the distributor cap, access to an allen set screw. Setting with a dwell is much more accurate.
More pictures of my former Goat:
http://www.barrett-jackson.com/appli.../w_search.aspx
My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K
And in the 2008 Scottsdale auction, Lot #960 - $80K
Eventually sold by Brighton Motor Sports in Scottsdale, AZ -$89,900
Old 06-26-2007, 06:29 PM
Thanks alot!! seems that my guess of .017 with a feeler guage was a good start until i get a dwell meter.
Old 06-26-2007, 07:47 PM
Andre's Avatar
Andre Andre is offline
Generally points right out of the box will be close enough to get the car running. Once you are ready to dial it in closely, a dwell meter/tach combo is a fairly inexpensive piece.
Old 06-26-2007, 10:31 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
You really don't need a dwell meter or feeler gauge to adjust the GM style externally adjustable point. Here's how my dad showed me to do it many years ago:
Start the car up and let it idle. Then use a screwdriver or allen wrench and slowly start turning the adjustment screw in. Continue until the engine starts to misfire. At that point the engine may die, if so don't worry about it. Then turn the adjustment screw out exactly 1/2 turn and your points will be set.
Then you can go out and buy that tach/dwell meter and see that you will be right close to the 30 degree desired dwell setting.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
