Old 07-30-2007, 10:10 PM
old65goat old65goat is offline
Question Headers for a '67 Bonneville?
Does anyone know what headers I could use for a '67 Bonneville? I searched around and doesn't appear as they exist - I know I have seen headers on big Pontiacs - just need to be pointed in the right direction, thanks, Tom.
Old 07-30-2007, 10:36 PM
Fat Cat's Avatar
Fat Cat Fat Cat is offline
Dougs headers are the only ones I know of. I believe they are still available through PY. Just got done installing a set on my 66 and wow is it a tight fit!
-Steve
"A bend in the road isn't the end of the road unless you fail to make the turn."
Old 07-30-2007, 10:55 PM
68Prix's Avatar
68Prix 68Prix is offline
I got the Doug's Headers on my original 68 GP. They are a nice and well worth the money. If your car is a column shift car they may not work with the linkage. I have not heard of a column shift car getting them installed so the linkage may give you clearance issues. Pat
Old 08-01-2007, 11:25 PM
rontiac's Avatar
rontiac rontiac is offline
I am 90% sure that 1st generation Firebird headers will work in your 67.
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
Old 08-01-2007, 11:54 PM
68Prix's Avatar
I tried a set of Hedman headers for the 67-69 Firebirds and they were not a good fit at all. After driving a bit the passenger side that I did not have to modify was damaged. The drivers side I had to modify two tubes. I know that Hedman's will not work, but maybe some other brands might.
I will say again spend the money on Doug's headers the flanges are much heavier and seal better and they seem like a solid header where the Hedman's were not solid feeling when hanging the exhaust with bad welds where they seal. Even after filing flat I never got them to seal good.
Pat
Old 08-02-2007, 07:28 PM
Fat Cat's Avatar
Yeah, I forgot to mention that the linkage is an issue when switching over to headers. My car was a column shift and I converted it to floor shift.
Old 08-03-2007, 10:17 PM
Pontiacdaver's Avatar
Pontiacdaver Pontiacdaver is offline
Has anyone here modified a set to clear the linkage, or can it be done? My '68 GP has the power Strato-bench and I wasn't planning to change it, but I did plan on installing headers on the 428.
Dave
2 wrongs don't make a right, 3 lefts do. 4 lefts make a NASCAR race but who cares?
2004 Grand Prix GT daily driver
1974 LeMans GT 455
Old 08-05-2007, 09:24 PM
kmccrystal's Avatar
kmccrystal kmccrystal is offline
You can always go with long branch headers. I found a set on a '68 GP and swapped them over to my Cat. I also did the console shifter at the same time so I don't know about interference with column shift mech. If you do use CI long branch headers you'll need the oil filter adapter too.
I have read the the long branch don't flow was well as true headers, but they are an option.
'68 Catalina convert. w/ 428, OEM long branch exh, QuadraJet, 3:23 Posi, GP front grille, GP bucket seats and GP tilt.
Old 08-08-2007, 12:20 PM
jku72 jku72 is offline
I put long branch manifolds on my 67 cat with column auto, no problems with linkage at all.
i did have to get the oil filter adapter, which now leaks though.
