Old 08-05-2007, 05:29 PM
RiceCooker RiceCooker is offline
Send a message via AIM to RiceCooker
Default hitting the juice
I was curious as to how and when you hit your nitrous.
do you guys use RPM window switches? How do you control it?
Does it matter what RPM you hit it with carb applications?
do you launch on nitrous?
Old 08-05-2007, 05:46 PM
RAIV55 RAIV55 is offline
If the car will hold with the additional power, hit the bottle when the throttle goes wide open.
I haven't used window switches but I've noticed some boosted applications use 'em. On traction limited cars setting up the low limit can get the car rolling without blowing the tires off.
Old 08-05-2007, 09:58 PM
issach428's Avatar
issach428 issach428 is offline
the best way in my opinion is a full throttle switch. Its one less thing you have to worry about. if something goes wrong and you lift, then the nitrous goes off until you wot again.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
Old 08-05-2007, 10:02 PM
but does it matter at what rpm you hit it?
when I ran juice on my EFI car, I had to be at like 3000 rpm before I hit it. If I can hook, than there's no reason not to hit it off the line???
Old 08-05-2007, 10:12 PM
David Holmberg's Avatar
I hit it right off the line, with throttle switch. I wouldn't run it below 3000 rpms, but most converters on the bottle will stall higher than that.
Old 08-05-2007, 10:19 PM
Brian Baker's Avatar
Makes no difference from what rpm you activate it, but the engine should be at WOT when doing so. Engine damage will not occur at lower RPM's regardless of fuel delivery (ie - carb or injection). I mean, come on...it's an internal combustion engine...all you're doing is throwing more fuel and air into, who cares at what rpm you start? Engaging it at lower rpm's (ie - at launch) may cause traction issues however. I would activate it with a microswitch set to go on at WOT, and hit it right on launch. Staged teh car at about 1500-1700 rpm and nailed it, convertor would flash to around 4500 on the bottle, and around 3200 off the bottle.
Old 08-05-2007, 11:58 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
It's fine to run the nitrous off the line if you can hook it. Also, when you do not have a purge kit installed, there will be a slight delay before the "Shot" kicks in. I recommend a WOT switch, they work and they are cheap. Finally, if you don't have a bottle heater or way to raise the pressure in the bottle you'll only get a full nitrous pass 1-2 from a full bottle. UNLESS it's super hot out side and mother nature is heating for you! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
