Old 09-02-2007, 10:29 PM
AdamHoud's Avatar
AdamHoud AdamHoud is offline
Default RA Manifolds came in today...concerns
So I received my manifolds today from RARE, they seem to be good overall except for the middle port on one side....here are some pictures.
1973 base firebird
Original 350, with 69' #46 heads, crower 60240, 9.3:1 cr
Old 09-02-2007, 10:43 PM
form74's Avatar
form74 form74 is offline
Adamhound, contact paul at Ram air and talk to him, he will make it right. He is very customer orientated.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 09-03-2007, 12:58 AM
Big Injun's Avatar
Big Injun Big Injun is offline
These are sand castings. Where you expecting a CNC port?
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 09-03-2007, 02:51 AM
Question 'D' Port shape, or sealing surface problem?
Adan, are you referring to the lack of material in the divider between the ports? I'm talking about the sealing surface only here.
It looks like there is not enough material in that area to clean up when the sealing surface was milled, like an incomplete casting. The 2nd and 4th pics look like this to me.
A small 'line' at the seam in the very center of the divider itself is acceptable, but not a big void where the entire divider won't seal against a gasket. Am I being fooled by the pics here? A little hard to tell exactly.
If I'm mistaken and you are only referring to the small imperfection (lack of material affecting only the 'D' port shape itself) at the bottom right corner of the port on the left, it's nothing to be concerned about.
Old 09-03-2007, 03:38 AM
AdamHoud's Avatar
I was referring to the line in the center, it runs on both sides of each port...just wondering if that is acceptable.
1973 base firebird
Old 09-03-2007, 03:58 AM
Quite a few factory manifolds are like that too, not an issue to be concerned about.
As a matter of fact, one manifold doesn't even have that center divider on most sets of stock standard log manifolds.
I would think that many sets of those new RA manifolds are like that, that won't affect the way they function. If you're using the stock steel shim manifold gaskets (I did with mine), they are wide-open in the center and don't even seal in the divider area anyway.
Old 09-03-2007, 04:02 AM
AdamHoud's Avatar
I have some fel pro gaskets to go with it.
1973 base firebird
Old 09-03-2007, 07:21 AM
GonicGM's Avatar
GonicGM GonicGM is offline
Are the fel-pros steel shim or paper. I'd use the factory style beaded steel shim myself. Additionally, a very thin coat of exhaust sealer, like walker acousti-seal, will help sealing and keep oxidation down.
Gregg V.
Old 09-03-2007, 12:10 PM
AdamHoud's Avatar
They are the white paper ones.
1973 base firebird
Old 09-03-2007, 12:33 PM
I got a set of the steel shim type PM me if you cant find locally.
Old 09-03-2007, 09:17 PM
form74's Avatar
Adamhound, I used the following gaskets on my R.A.R.E manifolds, can you guess where I got them. Don't use the plain steel ones.
ID:	103645   Click image for larger version
74 Formula
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Performer RPM
Old 09-03-2007, 10:22 PM
Formulabruce's Avatar
and boy do they oxidize fast!! coat them, and bake them ASAP.
" Long may we DRIVE !"
Old 11-02-2007, 11:26 PM
Dan Linebarger's Avatar
Dan Linebarger Dan Linebarger is offline
I have bought RAII and RAIV manifolds from Ram Air Restorations and both sets have been flawless.
Men feel younger by driving old muscle cars.
Women feel younger by doing a little "nip and tuck".
Both are expensive and darn well worth it!
Old 11-03-2007, 09:15 PM
Half-Inch Stud's Avatar
Divider imperfections will not hinder perf nor economy, heat/thermals, nor noise.
Yea, stock manifolds had the cast-void line there.
Old 11-03-2007, 10:35 PM
Default yes
You are right. I looked at the RAII exhaust manifolds I recently pulled off my car.
Pic attached:
Note: There is no gasket for the divider. It is not important.
Old 11-04-2007, 03:50 AM
baron_ baron_ is offline
Send a message via AIM to baron_
i'd be more concerned about the location of the mounting bosses for the exhaust pipes
they interfere with the 66/67 frame, if that's your intended use
grab the grinder and have fun
(don't know why they haven't fixed that)
Clay Marsh
1967 GTO convertible Twin Turbo 5spd project
http://forums.performanceyears.com/f...d.php?t=618281
http://www.youtube.com/watch?v=eJ9KworCMRE
Old 11-04-2007, 08:56 AM
YVEYANT's Avatar
YVEYANT YVEYANT is offline
Send a message via AIM to YVEYANT
I went with Felpro gaskets on my new R/a headers instead of the metal and they sealed great.
Ant
1967 Pontiac Tempest, GTO-Inspired
"What's so special about having Italian food cooked by a bunch of friggin Mexicans"
Paulie-
Rocky Balboa
"Your heart is free, have the courage to follow it"
Braveheart
http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg
Old 11-04-2007, 09:00 AM
The FELPRO fabric will act as a thermal barrier allowing your head to run cooler than the metal crush gaskets...less ping, more radiator cooling margin. HIS
Old 11-04-2007, 12:03 PM
Kenth's Avatar
Kenth Kenth is offline
Pic attached:
These are regular D-port RA manifolds, NOT RAII manifolds, RAII exhaust manifolds are O-port.......
Old 11-04-2007, 12:09 PM
Kenth's Avatar
How much is the temperature difference in the heads between the two different exhaust gasket styles?
