Old 09-20-2007, 10:15 PM
goat junkie goat junkie is offline
Default will 342 gears fit on a 410 carrier?
got a 12 bolt in my 69 gto. want to change the gears to 342, or 355. will they fit this carrier? thanks, mike.
Old 09-20-2007, 10:21 PM
GonicGM's Avatar
GonicGM GonicGM is offline
Probably not unless you have a ring gear spacer now or have a 3 series gear. The factory used a 2 3 and 4 series carrier, basically in the obvious range as stated. If your carrier casting is 30140 yes, 30174 no. I believe there is a 3.90 gearset made for a 4 series carrier.
Gregg V.
Old 09-20-2007, 10:39 PM
mikeb mikeb is offline
There is a "thin" 3.73 that is made for a 4 series carrier. Maybe also a 3.90, I haven't looked.
Old 09-21-2007, 08:41 AM
guthriesmith guthriesmith is offline
This is what I did with my 12 bolt. I had put a 4-series spool in the rearend with 4.10 pro gears. After changing direction with what I planned on doing with the car, the best solution was to buy the 3.73 gears for a 4-series carrier.
Old 11-02-2007, 10:45 PM
Dan Linebarger's Avatar
Dan Linebarger Dan Linebarger is offline
When I was told that I could not put 4:11's in place of my 3:23's without a carrier changeout, I went to: http://www.tomsdifferentials.com/
These guys know their rear-ends.
Men feel younger by driving old muscle cars.
Women feel younger by doing a little "nip and tuck".
Both are expensive and darn well worth it!
Old 11-03-2007, 10:34 AM
Overkillphil's Avatar
Quote by Dan: "These guys know their rear-ends"
I think I saw them on "Queer eye for the straight guy"!
Old 11-03-2007, 10:43 PM
Default Ha!
Good pun! OK-Phil, Ha!
Seriously what I meant to say was that when everyone else said I couldn't do it, Tom's had a spacer and saved me a fortune.
Dan
Old 11-04-2007, 08:59 PM
GonicGM's Avatar
Dan
Spacers have been around forever and most people know about them, no secret there. Spacers are generally frowned upon in the trade. The ring gear bolts are in double shear and depending on the carrier, the width of the ring gear piloting diameter is marginal with a spacer to properly center the ring gear on the carrier.
Gregg V.
Old 11-04-2007, 11:17 PM
Default Thanks
OK, I'll keep that in mind.
