Old 01-14-2008, 10:47 PM
Steve Barcak's Avatar
Default GMCs with Pontiac power
I have found a few more I wanted to share here. Of course, if anyone else wants to add, please do so.
This first one is a '55 1 ton. Motor is gone but the V8 emblems are there. The guy is planning to convert it to a street rod type pick up configuration. I'd leave it a 1 ton. Not for sale right now but, I heard it may be later.
Steve Barcak www.pontiacheaven.org
"Real Pontiacs only....no corporate nonsense!"
ID:	118473   Click image for larger version
ID:	118474   Click image for larger version
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 01-14-2008, 10:54 PM
This sweetheart I found last Saturday at my churchs annual car show. Very, very, nice. I invited him to Pontiac Heaven in April. It would be great to see this participate. I thought I got a picture of the motor but, I guess I did not. It has a restored 316 painted red with GMC decals and a hydro bolted behind it. He told me he and his wife rebuilt the whole truck, including the hydro. Said going through the trans was not too hard and it now works just fine.
ID:	118479   Click image for larger version
ID:	118480   Click image for larger version
Hosting-
Phil 2:11
Old 01-14-2008, 11:10 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
I saw a '58 Jimmy medium duty at a show and the owner claimed it was a 370 cid V8. I know the trucks also had an oddball 336 cid V8 also. Wonder if a 389 was ever dropped in before GMC offered its own V6 -
That '55 you have pictured is the second series; they used the old body mid way through '55 for some reason.
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 01-15-2008, 12:52 AM
Bill Hanlon's Avatar
If they did it wasn't official. I have two GMC Master Parts Books, neither of which mention 370 or 389 Pontiac engines. Some people confuse the 370" gas V8 offered in the larger (550 series and bigger) 57-59 GMC trucks as a Pontiac engine, but it was actually based on the Oldsmobile 371" V8 of the same year.
Old 01-15-2008, 04:02 AM
I saw a vintage Jimmy with a Olds 371, guy who restored was not sure it was original, now it sounds like it was.
Personally, I prefer a screaming Jimmy 2 stroke
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 01-15-2008, 04:17 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Steve, Steve... you know darn well my truck isn't photogenic now!
Oh well... here's an old picture of it orange. It will be going back together blue and white.
ID:	118552   Click image for larger version
Old 01-15-2008, 11:16 AM
Only if were 2 ton or bigger.
Wouldn't be hard to drop the Olds engine into the smaller truck though, as the front engine mount is similar (same?) and attaching a Hydra-Matic to an Olds is a very natural thing to do.
Old 01-16-2008, 12:37 AM
This '55 is actually a '57. Or at least it has a '57 grille. Check the VIN plate on the driver's side door jamb. If serial number has a T as the 5th character, then '57. '55 would have a Y as the 5th character of the serial number.
Old 01-17-2008, 01:32 PM
stevep's Avatar
stevep stevep is offline
A customer from CT just dropped off his 1957 GMC PU with a Pontiac V8 and a Hydramatic for me to rebuild the trans. It has been off the frame and is jammed, but not full painted yet. He would LOVE to find a Power Steering set up for-it.
Old 01-17-2008, 03:16 PM
Is he looking for "stock" power steering? Those things are made from unobtainium, although most parts are interchangable between 1/2 to thru 1 ton models.
A knock off of the Chevy power steering is available at CPP here:
http://www.classicperform.com/power1.html
Other kit alternatives when staying with the I beam front axle include:
1. an 800 series 70's GM truck power steering box mounted on the outside of the frame forward of the front axle (I have this and don't like it - bump steer because of short drag link)
2. a Toyota 4x4 power steering box mounted where the original box was
3. a rack and pinion mounted to the back of the I beam
All three could use the original power steering pump available for the Pontiac V8. The mounting bracket for the pump is the same from 55-59 truck and 55-57 Pontiac car. 58 car bracket is somewhat different, although it still uses the same two holes on the top of the timing cover and would work OK in the truck. I got my pump and bracket from a '56 Pontiac. Found a rebuild kit (new seals and bearings - vanes not included, mine were OK) for the pump in New Jersey (the guy advertises in Hemmings) and rebuilt it myself.
Old 01-17-2008, 06:46 PM
I'll take a screamin' Jimmy over a gasser anyday
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 01-17-2008, 06:58 PM
stevep's Avatar
The guy found a truck with power steering and was going to buy it but he told a friend about it. Turns out that the friend wasn't really a friend as HE bought the truck and my customer was SOL.
Old 01-17-2008, 10:38 PM
Default How rare is GMC power steering?
Over on the OldGMCTruck forum there has been talk in the last year of complete original working 55-59 GMC power steering systems going for $4K.
Old 01-18-2008, 04:12 AM
I guess it's just as well that I quit looking for one!
Old 01-20-2008, 04:36 PM
http://auto-rv.com/browse.aspx?AdName=CHLI2400050
now this'd make a cool hauler. it should be in good shape also being an old fire truck.
mike
former." --Albert Einstein
- Winston Churchill
Old 01-20-2008, 05:08 PM
Beats the he!! out of dropping in a "ho-hum" common 350 Chebby like everyone else does. You ever seen what happens to Chebby 350s when they were put in C60s and C70 Chebbies ?
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 01-23-2008, 07:43 AM
timbo timbo is offline
Default 51 GMC
I have a 51 GMC half ton. I'm thinking of putting a Pontiac motor in it. I'd like to put a OHC 6 cyl/4 bbl in it. There was 1 on a website awhile back, I thought it was here, but can't find it. He put a V8 Pontiac in it. Thanks!
Old 01-24-2008, 04:56 AM
I think an OHC-6 in an early Jimmy would be way cool.
Old 01-24-2008, 09:59 PM
Tin Injun Tom Tin Injun Tom is offline
mike
I saw that in the magazine, Mike. I was wondering if it might possibly have a Poncho V8.
Old 01-25-2008, 04:49 AM
The ad says "V8", so it would have come from the factory with a Pontiac, unless it's larger than a 500-series truck.
