Old 02-21-2008, 08:17 PM
davo1977 davo1977 is offline
Default 6 speed tranny in my 79 TA??
I have a 79 TA. Just bought a 600HP 454 BBC. Does anyone know if a T56 6 speed transmission will bolt up to this engine. Does anyone know if the shifter will be in the correct location? Is there anyone here that has done it?
Old 02-29-2008, 06:33 PM
67_Redbird's Avatar
67_Redbird 67_Redbird is offline
Yes it can be made to work with a BBC. I had a 6 speed in my 70 camaro, and used the stock pedals & stock mechanical (non hydraulic) linkage. Worked great.
Is your trans LT or an LS model? It will make a difference. LT trans are easier to make work. Mine was an LS model & I bought a McLeod Industries adapter plate at Summit.
There are a few more things you'll have to figure out. X-member, speedo, and get your driveshaft shortened. Your shifter will be about 4 inche further back than stock location as I recall.
PM me if you need more details.
Good luck
pics of my Firebird here: http://www.cardomain.com/ride/2297038
