Old 02-22-2008, 01:21 PM
BILL BOWMAN1's Avatar
Default CD player jam
I have a 2005 Silverado, used. There is a CD jamed inside the player. I hit eject, it makes a grinding noise like it is trying to eject but it won't, and I know there is one in there, cause I tried to use it and it ate it, It didn't even play. I don't think this is a easy 5 minute fix, has anyone had the dash or radio apart on one of these yet? Sounds like a dealer job?
Thanks,
Bill
Old 02-22-2008, 02:50 PM
rowling rowling is offline
I had the same thing happen on my Yukon and I gave up on it. The other week I left the interior lights on overnight and killed the battery. After I boosted it with my GTO battery the CD player started working and ejected the CD.
So maybe try something quick and easy like disconnecting your battery - it won't cost you anything.
Glen.
Old 02-22-2008, 03:23 PM
DBONES152's Avatar
DBONES152 DBONES152 is offline
Location: Illinois-Where Our Ex-Governors Make Our License Plates
I had it happen in my 2002 Tahoe. Like rowling said, try pulling the fuse or disconnecting the battery for a minute or two, then re-connect. It worked for me - spit it right out.
Plans are what you make when you want to hear God laugh!!
Old 02-22-2008, 03:24 PM
It's worth a try, Thanks.
1967Clone's Avatar
1967Clone 1967Clone is offline
Try and insert another CD, it might just eject the "stuck" one.
Old 02-22-2008, 04:49 PM
OhMyGoat's Avatar
OhMyGoat OhMyGoat is offline
I usually take another disc and poke around in there. It usually pops out after a couple trys...2006 Silverado.
Alan
Tomorrow is often the busiest day of the week.
Old 02-22-2008, 05:17 PM
johnsma22's Avatar
johnsma22 johnsma22 is offline
Was it a store bought cd or a cd-r made on a computer with one of those stick on labels? If it was the latter, the stick on labels can wreak havoc with slot loading drives.
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 02-22-2008, 06:20 PM
Silver Judge's Avatar
Default Re-boot your Silverado
Disconnecting the battery and re-connecting sounds like a good idea.
Completely separate problem for me recently was the light in my very expensive oven at home, it was going on and off like it was completely going nuts. There is no on and off switch so I killed the breaker to that circuit. Turned it back on and the problem went away.
I may be the only person that has re-booted their oven, like we sometimes have to do with our doggoned personal computers !
501 HP, 554 ft lbs TQ
Old 02-23-2008, 07:20 PM
Well I tried the batty disconect idea, it tried to eject but wouln't. I did eventually get the cd out with a couple of butter knives last night. Today I disconect the battery again but nothing further happened, it won't take a cd when I try to put one in. I think it is up to a professional stereo shop from here.
Thanks,
Bill
Old 02-23-2008, 08:01 PM
zbuickman's Avatar
zbuickman zbuickman is offline
O/T but let me guess it is a WOLF range?????
Brent
65 "X"vert
84 T-Type
my cars
Old 02-23-2008, 11:29 PM
fyrffytr1's Avatar
Bill,
It is a simple job to replace the radio. Just pry the dash surround loose, Then compress the release levers on either side of the unit, pull it out and disconnect the wiring. You can probably get a unit from the local junkyard or try a radio shop that pulls stock units to install upgrades.
I got one on e-bay for $35.00.
