Old 06-27-2008, 05:11 PM
1971/455/HO/4-SPD's Avatar
1971/455/HO/4-SPD 1971/455/HO/4-SPD is offline
Default 1979 WS6 Options
What options were included in the WS6 package? Thank you!!!
Admiration for Ponchos..........
Old 06-27-2008, 05:50 PM
Don 79 TA Don 79 TA is offline
not that i am an expert but larger sway bars (i don't recall if the front was larger) but rear was 1" opposed to the 7/8"
quicker ratio steering box
and weren't the snowflakes a little different?
there was also something about a control arm brace
i don't recall if the 6x-4 heads were on the WS6 or not
this is all assuming i am correct, if not others will chime in
WS6 3rd gens had some other differences (different ball game i know)
Old 06-27-2008, 06:06 PM
David Holmberg's Avatar
4 Wheel disc brakes (Not included in 1978)
8" aluminum wheels
Larger sway bars
Quicker ratio steering
Old 06-27-2008, 06:35 PM
74 SD455 Formula 74 SD455 Formula is offline
I thought that poly urethane bushing as well as the 8in. Snowflake Wheels,4 Wheel disc brake's,quick ratio steering,fatty sway bars and I have never seen one without a posi unit.The WS6 option was manditory on the Formula's with the 400ci 4spd. option in 1979.
Old 06-28-2008, 04:15 AM
2manyT/A'S's Avatar
Posi (Safe-T-track) was standard equipment on ALL 70-81 WS4's (Trans am option code)
In 1981,it became part of the WS6 package & optional on WS4
