Old 09-07-2008, 12:16 PM
altfueler altfueler is offline
Send a message via Yahoo to altfueler
Red face source for angle finder to set pinion angle?
Looking for a source for an angle finder to set my pinion angle. Is 2 degrees + a good start? I am installing no hop bars AND adj up cont arms on my 72 Lemans 455,th400, 12bolt 4:10
Old 09-07-2008, 01:29 PM
Doug Doug is offline
Thumbs up angle finder?
Try Lowe's tool department.
There has been a lot of discussions on this "pinion angle" stuff on these boards. I suggest you do some in-depth research. There are a lot of variables to consider such as: street or drag driving, air bags, shocks, ride height, tire diameter, etc.
Old 09-07-2008, 08:04 PM
bluebandit bluebandit is offline
I got mine at Sears.
Old 09-07-2008, 08:23 PM
360Rocket's Avatar
360Rocket 360Rocket is offline
If its not a job you plan on doing over and over, just go rent one from the auto parts store.
Old 09-08-2008, 05:39 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Don't just set the angle at the rear end. You have to consider the angle at both ends of the driveshaft to do the job correctly. Here is one of the best explanations of the procedure I've seen.
http://www.rosslertrans.com/Pinion%20Angle.htm
You can get an angle finder at Harbor freight pretty cheaply that works good.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 09-09-2008, 01:40 AM
goatman65's Avatar
Sears,9.99.Or a smaller one for 4.99
