Old 09-17-2008, 12:58 PM
steve25 steve25 is online now
Default SB chevy cam info
hey , does anyone know how much lift the fuel pump drive lobe should have, I got a friends car that has fuel delivery problem.
Old 10-17-2008, 10:19 PM
440GP69's Avatar
440GP69 440GP69 is offline
I'd be checking other issues before that, i bet its a fuel pump issue or fuel lines routed wrong, clogged filter?
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 11-01-2008, 12:49 AM
engineer engineer is offline
look at pump, spring on pump arm, pump shaft and if pump has been changed or removed recently, then check it has not shifted position.
